This panel is a sub panel down stream from the main panel to the home. Aren't the grounds and neutral suppose to be separate? Would you just add an additional bus bar? And can you explain the reason why this should be done. I could not find anything on this in any of the message boards.
[ATTACH][/ATTACH] Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Another Old Soldier Fades Away... | dandersen | Miscellaneous Discussion for Inspectors | 0 | 12/7/08 6:19 PM |
| Insurance-scarred Florida emigres stream to Atlanta | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 6/27/07 5:08 AM |
| Under ground stream | bnelson | Exterior Inspections | 4 | 1/31/06 11:08 PM |
