Old 2/15/07, 2:20 PM
Karl E. Gerhauser's Avatar
Karl E. Gerhauser Karl E. Gerhauser is offline
Question Driploop connections
The drip loop appears to be keeping water away from the weatherhead, but is directing the water onto the mechanical connections. Is this truly a problem? Please give me your opinions or in the applicable rules of possible. Thanks, Karl.
Old 2/15/07, 5:48 PM
Marc D. Shunk's Avatar
Banned
Default Re: Driploop connections
I recognize that connection as being a Burndy H-tap connection. It may be buried, underwater, subject to rain, any just about any other environmental condition that can be thrown its way. The connection, when made with approved tooling, is "gas tight", and will not corrode. The connection is also prefilled with oxide inhibitor. The H-tap cover is also self draining, and will not hold water for long, and is of a design that promotes airflow within the clamshell type cover.
Old 2/15/07, 5:50 PM
I don't see a problem with the drip loop.
Larry Kage, CMI
231 929 3525
Old 2/15/07, 6:30 PM
Thank you for the comments.
Old 2/15/07, 9:25 PM
I see a problem with the TV Cable connecting to the MAST.....tell em to get their own POLE....
230.28 Service Masts as Supports. Where a service mast
is used for the support of service-drop conductors, it shall
be of adequate strength or be supported by braces or guys
to withstand safely the strain imposed by the service drop.
Where raceway-type service masts are used, all raceway
fittings shall be identified for use with service masts. Only
power service-drop conductors shall be permitted to be attached
The CODE is for those CODE HATERS out their......Suck it UP....
Paul W. Abernathy
Ground connections dmacy Electrical Inspections 1 5/7/07 7:58 PM
Plumbing pipe connections Homewood Plumbing Inspections 3 3/1/07 4:44 PM
Manifold connections, mixing valve question jclark1 Plumbing Inspections 14 6/15/06 10:46 PM
Are these proper connections? jweinberg Plumbing Inspections 9 5/25/06 8:32 PM
Bad connections bkelly1 Plumbing Inspections 0 3/4/06 11:20 AM
