Old 4/11/06, 4:03 AM
Rafael Rafael is offline
Please Note: Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default dryer 240 burnt plug
Hello guys
With this picture of a dryer plug with burn marks around what
is the cause of this?
dryer-240-burnt-plug-plug-18x18.jpg   dryer-240-burnt-plug-plug-att340x240.jpg
Old 4/11/06, 7:52 AM
David P. Valley's Avatar
Default Re: dryer 240 burnt plug
It could be one of many different senarios that could cause this plug to melt.
My guess....
Undersized wiring for this particular circuit?
Old 4/11/06, 8:18 AM
N5XL N5XL is offline
Please Note: N5XL is a non-member guest and is in no way affiliated with InterNACHI or its members.
My guess...
weak receptacle (weak holding strength...I see this a lot on cheap 15amp 120v general purpose outlets in the house)
Dave
Old 4/11/06, 10:53 AM
loose connections at the receptacle will cause that also. I've seen it a lot on one pin, your's is the first I've seen on both.
Old 4/11/06, 10:58 AM
jwortham jwortham is offline
Please Note: jwortham is a non-member guest and is in no way affiliated with InterNACHI or its members.
Brian and N5 are right.
The plug is shot.
Current flowing through the bad connection is heating the prongs which is melting the plug.
Client show you that or did you unplug it for other reasons?
Old 4/11/06, 4:16 PM
My house . I just happen to unplug it to clean around the dryer and
check for any clogged lint in the hose and saw this . I dont know how long
this has been like this but the house is 18 yrs old. Should i relace the plug
and check for any loose connections ?
Old 4/11/06, 7:41 PM
Paul W. Abernathy's Avatar
I agree......more often than not it was probably just poor connection at the contact areas...causiing arcing and heating.
If you were asking what I would do....I would replace the receptacle plug as well as the cord to the dryer..But thats me...
However.....someone made a good point....make sure the wire to the dryer plug is most certainly 10 AWG wire...atleast....
Paul W. Abernathy,CMI,CPI,CME
Old 4/11/06, 8:44 PM
Thanks guys
Old 4/12/06, 1:38 AM
I agree with Paul A. You should definitely replace both the cord and the recep.
Until I blew the photo up, I thought that it might be corrosion caused by moisture, but on closer examination, you can see the melted plastic near the phase blades, and of course there is no damage to the ground pin. Odd that it occurred at both blades. I think I will run downstairs and check mine.
Old 4/12/06, 7:54 AM
Rafael,
What size wire is feeding the dryer circuit?
Old 4/12/06, 11:28 AM
Most certainly while you are doing all the checking.....do as Mr. Valley stated....check the wiring....also while you are changing the PLUG...take a GANDER at the insullation on the conductors as well....just to ensure they are fine and no discoloration has occured and so on...
Old 4/12/06, 1:16 PM
Changing the plug won't fix anything, this is a bad receptacle that is burning up the plug. I bet it looks like the one Joe T posted the other day
Old 4/12/06, 1:20 PM
I think Paul hit it.
Old 4/12/06, 1:46 PM
I would agree that the problem is more in the recptacle and should be replaced...and check the wiring to the recptacle, as well.
However, I don't think I would trust that plug or cable and replace that also.
But then, what do I know? I'm just an old fart waiting for Godot.
Old 4/12/06, 1:48 PM
Good lord, am I taking issue with Greg Fretwell?? He and Bob B are my heroes...oh, dear...
Dryer sheets potential hazard badair Miscellaneous Discussion for Inspectors 15 7/9/11 3:39 PM
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 8 9/9/07 8:02 PM
Dryer lint filter senomoto Miscellaneous Discussion for Inspectors 6 5/14/06 11:01 AM
Bad Dryer and Bath Fan Venting Jkrt00 Inspecting HVAC Systems 3 3/14/06 12:07 AM
