Old 1/29/10, 11:34 PM
Carl E. Nagy's Avatar
Carl E. Nagy Carl E. Nagy is offline
Location: Jeromesville, Ohio - Serving Ashland County, Ohio and Surrounding Areas
Question Dryer with 3 wire feed and ground to water pipe
In my personal residence if have a dryer in the basement with a 3 wire feed. The neutral in bonded to the dryer frame as it should be under the code at the time. There is also a ground wire run from the back of the dryer to a nearby water pipe. I realized the other day that this puts the water pipe in parallel with the neutral in the feed. I pulled out my trusty clamp on ammeter and put it on the bond to the water pipe and measured 1.6 amps with the dryer running. This would likely be a portion of any unbalance on the two hot legs. So, all that said, is the bond to the water pipe a bad thing or a good thing? Or am I giving everyone a headache and I should go post this at Mike Holt? I realize that a 4 wire feed is what should be there. On my list for future improvements.
Carl Nagy
CENTech Property Inspections LLC
cnagy@oh.nachi.org
Jeromesville, Ohio 44840
419-368-5814
Serving Ashland, Mansfield, Wooster, Akron, Canton and Surrounding Areas
Old 1/30/10, 1:08 AM
Bruce A. King's Avatar
Default Re: Dryer with 3 wire feed and ground to water pipe
It is not good, you could have or develop a bad connection at another water pipe bond or something wrong with the neutral going to the dryer somewhere. I would upgrade the whole circuit for the dryer and make sure the water piping was bonded elsewhere as it should be.
www.BAKingHomeInspections.com
704 301-3207
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
