Old 3/26/06, 11:10 PM
Joe Funderburk, CMI's Avatar
Default Dryer Outlet Testing?
Do you guys test dryer outlets? If so, what method to you use?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/26/06, 11:12 PM
tneumann's Avatar
tneumann tneumann is offline
Default Re: Dryer Outlet Testing?
Turn dryer on..if it spins and heats...outlet works
Actually, I never thought of this....what if they move in and the outlet doesn't work?
Old 3/26/06, 11:13 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
try turning on the dryer. i just use the "as the homeowner would do" method. if no dryer present, i use my multimeter and test both legs for 120vac. and state that power is present, unsure of dependiblilty.
Old 3/26/06, 11:14 PM
Jay Moge's Avatar
damn Tony, you beat me by about 5 seconds.
Old 3/26/06, 11:18 PM
Yep...that's what I'm wondering. I've never checked them. Starting to question my practices.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/26/06, 11:20 PM
tneumann's Avatar
you would think that would be disclosed by the seller....pretty sure they would know eh?
And if not disclosed..you would think they would go after them....what do the SOPs say?
Old 3/26/06, 11:28 PM
Jay Moge's Avatar
as far as i know (and in my report) it states that a "represented" number of outlets, switches and windows and doors are tested. not EVERY SINGLE ONE. i'd guess that would cover my butt if the outlet wasn't tested, and tunded out to be dead.....i hope.
Old 3/26/06, 11:32 PM
tneumann's Avatar
I choose the representative receptacles to be the ones my tester fits into...and not the ones that hurt really really bad when it hits you
Old 3/26/06, 11:53 PM
Bruce A. King's Avatar
As Joe Ferry would say, the reasonable typical inspector only uses a regular outlet tester....
Many meter leads will not reach into these outlets reliably and could lead you to believe that no power exists.
I might start stating in the report that 220V receptacles are not tested.
www.BAKingHomeInspections.com
704 301-3207
Old 3/26/06, 11:57 PM
tneumann's Avatar
220 is an owie too.....
Old 3/27/06, 3:03 AM
A more definititive test would be to check across the hots for 240v. It could be wired wrong and get 120v to ground from both sides.
Old 3/27/06, 3:29 AM
Russel Ray's Avatar
We test outlets if there is nothing plugged into them.
Since we have a lot of gas around here (!), the 220V outlet usually doesn't have anything plugged into it, so we test it.
Old 3/27/06, 6:44 AM
nbhi's Avatar
nbhi nbhi is offline
Ray, what method do you use to test 220v?
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 3/27/06, 7:25 AM
David P. Valley's Avatar
Joe,
I use the FLUKE testers. They're very easy to use in testing for continuity at ANY receptacle.
Old 3/27/06, 9:59 AM
Russel Ray's Avatar
I use the same things David does.
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 8 9/9/07 8:02 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Testing a dryer outlet acox Electrical Inspections 14 7/27/06 11:51 PM
Dryer Outlet sboyd2 Electrical Inspections 5 5/27/06 1:27 PM
