I know...I know..."we are not code inspectors".
This is for anyone who wants to play along. Anyone see anything wrong?
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I used to leave my gum under the desk.
That's a very nice staple you got there.
If it's 1.25" from the edge of the stud then it looks fine to me.
Do you see the 2"-2-1/2" staple?
Yup, but what does that have to do with this being an electrical code test? The requirement is that the hole edge be 1.25" from the wood edge. Looks like it's in the center of the wood which makes it compliant, unless I'm missing something?
Good catch that makes me wonder if that is what they secured the conductors to the studs with.
Defiantly would be wrong. |
I don't see it Joe. What gives?
3 or more cables with 2 or more current carrying conductors must be derated if installed through the same hole without spacing present. The firestop caulk prevents the spacing. NEC 334.80
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Me too
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
Even if it's through only one stud?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
One other thing. How do we know they are through the same hole? Each wire could have it's own hole but covered up.
Reason 12 :I hate that extension cord stuff.
E3705.4.4 Conductors of Type NM cable. Conductors in NM cable assemblies shall be rated at 90°C (194°F). Types NM, NMC, and NMS cable identified by the markings NM-B, NMC-B, and NMS-B meet this requirement. The ampacity of Types NM, NMC, and NMS cable shall be at 60°C (140°F) conductors and shall comply with Section E3705.1 and Table E3705.5.3. The 90°C (194°F) rating shall be permitted to be used for ampacity correction and adjustment purposes provided that the final corrected or adjusted ampacity does not exceed that for a 60°C (140°F) rated conductor. Where more than two NM cables containing two or more current-carrying conductors are installed, without maintaining spacing between the cables, through the same opening in wood framing that is to be fire- or draft-stopped using thermal insulation, caulk or sealing foam, the allowable ampacity of each conductor shall be adjusted in accordance with Table E3705.3. Where more than two NM cables containing two or more current-carrying conductors are installed in contact with thermal insulation without maintaining spacing between cables, the allowable ampacity of each conductor shall be adjusted in accordance with Table E3705.3. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 10:48 AM |
