The department of buildings in Chicago, apparently signed off on the electric meter being placed this close to the rear doorway of this town home.
But it just seems wrong to place it this close to a doorway and foot traffic. Does anyone have anything on required setbacks for electric meters? Thanks for your help. http://www.inspectorturley.com 1(847)494-3319 "You must learn from the mistakes of others. You can't possibly live long enough to make them all yourself." - Sam Levenson |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I'd say it's probably less about the "door" and more about the lack of required working space. There should be 30" of horizontal working space for that box and meter.
Yep. There appears to be a panel box below the meter. I guess you'd have to lay down to work on it.
There's nothing to open below the meter.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
This is a power company decision on where to place the meter.
Thanks for the feed back guys.
If that's the case, then its fine in my view. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Should be minimum 30"wide centered, 36" clear space in front, and 6'6" clear space from ground. Thats the way I know it.
30" width is correct, but it doesn't have to be centered in that space.
A meter is not necessarily service equipment so it doesn't (usually) pertain to the working space requirements for service panel. BTW - there is no minimum height requirement for service panels that I could find.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Working space requirements pertain to "equipment," not only "service equipment."
Working Space. Working space for equipment operating at 600 volts, nominal, or less to ground and likely to require examination, adjustment, servicing, or maintenance while energized shall comply with the dimensions of 110.26(A)(1), (2), and (3) or as required or permitted elsewhere in this Code. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| CPSC -----> Recall on electric meter panels | pbolliger | Electrical Inspections | 0 | 10/15/09 11:23 PM |
| Electrical Safety Media Center | jtedesco1 | Electrical Inspections | 1 | 3/15/08 8:18 AM |
