Old 4/20/11, 8:21 PM
Jeff Merritt Jeff Merritt is offline
Default Electric panel bonding & grounding
OK, this is Chicago, the land of conduit, this is a condo, with main breaker at meter in close with sub panel with a main breaker in panel, the neutral bus bar on the right side of the panel is floating, the on on the left side is not with a steel strap connection each.
electric-panel-bonding-and-grounding-100_8894.jpg   electric-panel-bonding-and-grounding-100_8895.jpg   electric-panel-bonding-and-grounding-100_8896.jpg
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/20/11, 9:01 PM
Robert Meier's Avatar
Default Re: Electric panel bonding & grounding
Does the horizontal bar connect the terminal bar on the right with the one on the left? It should be insulated from the enclosure, is it?
Old 4/20/11, 9:27 PM
Yes they appear too, the bar runs under the main bus, I am racking my brain to remember if I have ever seen this
Old 4/21/11, 1:34 AM
Jeffrey R. Pope's Avatar
It doesn't look to me like the left-side terminal bar is properly isolated. It also appears that both terminal bars are bonded by the "strap."
You only lend to confusion when you refer to a disconnect in a sub panel as a "main breaker."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/21/11, 5:03 AM
I had to think about this for a minute because your answer seemed obvious at first.
So what would you call that breaker in the subpanel? Panelboards usually come in two versions MLO (main lug only) and MAIN breaker. I would call the breaker at the meter the service disconnect and the breaker in the sub a main breaker.
Old 4/22/11, 10:03 AM
mwolff mwolff is offline
If the neutral is floating like you said, then then neutrals on the left side are in the wrong location. It looks to me that there is a lug on the right side of that ground strap, for a ground wire, if it were run with the other feeder conductors. It looks like they are using the conduit for the equipment ground.
Old 4/22/11, 10:43 AM
As an electrician, this stuff is academic to you Robert, and calling this the "main breaker" is quite reasonable. However, for some reason, it seems that many inspectors have a difficult time making the differentiation between "service equipment" and "other equipment."
Using the term "main" when referencing panels or breakers seems to perpetuate this confusion among inspectors, which is why I suggest using the the terms "service" and "other" when referring to equipment/panels and breakers/disconnects.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/28/11, 1:07 AM
Richard L. Overton Richard L. Overton is offline
Seems to me breaker or not, this is a sub panel and the neutral (grounded conductor) should float. White wires should all be on the right and the bonding jumper(flat cooper strap running behind the bus bars) should be removed from the right bus. The left bus would be reserved for ground wires.
Some jurisdictions require main disconnect to be accessible to the condo occupant, hence second "main breaker" in this panel. ITE panel?
Old 4/28/11, 2:10 AM
Bob Elliott's Avatar
I would still call it the main breaker to the remote distribution panel.
Looks like they mixed neutral and ground at the sub which is a no no since the box is grounded and also bonded to the neutral bar.
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
