Old 12/2/06, 12:49 PM
Russel Ray's Avatar
Default Electric panel help needed
Here's an electric panel that is perplexing me, and I'd like some help with it. Unfortunately, I was not at this inspection, and the inspector who did it is out in the boondocks in western Colorado or somewhere like that. I hate working from pictures alone.
Thanks.
Old 12/2/06, 12:58 PM
nwagner's Avatar
nwagner nwagner is offline
Default Re: Electric panel help needed
Looks like a sub panel. I've seen an older one like this one that only had a neutral bus bar, so the ground conductors terminated inside the panel. Most of the conductor ends were touching the panel, too.
Old 12/2/06, 12:59 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Nice paint job RR
It appears the the neutral bar is bonded to the panel, can't tell from the photo if the grounds are tied down or not.
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/2/06, 1:08 PM
Russel Ray's Avatar
It is a subpanel. The main panel, which only had a service disconnect in it, is out at the meter. This was a large townhouse.
Old 12/2/06, 1:09 PM
Russel Ray's Avatar
Ooooooooops. I hope Jeff Pope doesn't see that.
Old 12/2/06, 1:10 PM
Russel Ray's Avatar
Originally Posted by bgraham
Nice paint job RR
You like that? One of the "best" I've seen recently, and I didn't even have the privilege of actually seeing it. Darn.
Old 12/2/06, 1:24 PM
Paul W. Abernathy's Avatar
RRay,
Firstly, It is a "Sub" panel because of the attempt to seperate the grounded and grounding conductors......however can't verify the 4th wire in the images so I will leave that to you....or who ever inspected it.
Second, other than it being installed wrong......the Split Bolt used here is not designed for the number of wires inside of it...that split bolt connector is designed for (2) wires only......
Third, you know about the overspray issues in here as well as the missing Ko's....thats a given.....
Also I would assume...( now thats assuming ) that this is a 12 circuit panel...but the number of ACTUAL OCPD's within this panel would exceed the rating of the panel.....you know tandoms could as (2) OCPD devices....so without knowing the actual listing number...that could be another thing..
Also not to mention the attempt to use a half opened KO as a connector...is also another issue......
In the end....DEFER.....
Paul W. Abernathy,CMI,CPI,CME
Old 12/2/06, 1:50 PM
Russel Ray's Avatar
There was never any question about that.
It's that split bolt connector that I was most unsure of, not to mention the fact that I didn't know the terminology.
As always, thanks.
Old 12/2/06, 5:38 PM
No problem my brother...but if I am ever in California.....I'll have one of those DRINKS you speak of....
Old 12/2/06, 5:42 PM
Jeffrey R. Pope's Avatar
I would simply recommend replacement of that panel, regardless of what you want to call it.
Sorry, I've been out working all morning. This was my first opportunity to visit the MB
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/2/06, 6:21 PM
Russel Ray's Avatar
That was close.
Old 12/2/06, 7:23 PM
As always, thanks.
Also, the Split Bolt is also called a Bug Nut, or Servet which was the trade name for that product long ago, and we also find Burndy who makes them too.
Old 12/2/06, 7:30 PM
Russel Ray's Avatar
Thanks, Joe.
Old 10/15/08, 1:27 AM
Jay dee Jay dee is offline
Please Note: Jay dee is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by pabernathy View Post
RRay,
Lots forget the KO's and it could use a sharpie or somthing
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 72 3/12/08 12:19 AM
electric panel question etrippe Electrical Inspections 10 5/6/07 9:36 AM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
