I did an inspection today and the electric service panel is located in attic and the wiring entering and exiting panel is not protected by sheetrock and the incoming service wiring is wrapped in a rubber cover and ran along floor of attic to service panel. I have never seen a service panel in attic and 1. Can it be in attic, 2. Does wiring entering and exiting panel need to be protected with wall covering and 3. Are you allowed to run main service wiring on attic floor? Thanks for the input.
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
That is a difficult one to answer. I need to know some things first.
Where is the main breaker that shuts the power off to the house? Is the panel easily accessible? Such as, does the attic have a floor with steps going to the attic? Can you step on the main entrance cables? |
The main cutoff is on outside of home, there are no stairs to attic it is a walk in and the entrance cables could be stepped on they are ran ontop of floor decking in attic.
I would recommend removal to an accessible location but I would check with your local code authority first. Some code officals read codes in a weird way.
If the attic panel contains the majority of the circuits for the home, it's location would be a major inconvenience unless attic access is relatively easy, such as through a walk-through door. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| General Electric Panel/ Ground Wires | pnarron | Electrical Inspections | 18 | 6/5/10 9:25 PM |
| Plastic Square D service panel | bhartley | Electrical Inspections | 43 | 1/31/10 10:43 PM |
| 1 service panel 2 aux panels | mnicholet | Electrical Inspections | 4 | 7/4/08 7:59 PM |
