Old 8/12/11, 3:37 PM
Kenny Rigler Kenny Rigler is offline
Default Electric Water Heater Wiring
Hey Guys-
I'm replacing my gas water heater with an electric one. I was surprised to read from multiple sources, including the manufacturer diagram, to use only a 10/2 conductor and connect the neutral to the 30 amp double-pole breaker to get the 240 volts. And of course, put a piece of black tape around it to indicate its hot. But I thought it was a violation now to use the white conductor as an ungrounded conductor?
Kenny
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/12/11, 3:42 PM
RUSSELL SHUEY's Avatar
RUSSELL SHUEY RUSSELL SHUEY is offline
Default Re: Electric Water Heater Wiring
How else would you get 240v?
You are identifying the white as an ungrounded conductor by marking it with black tape in the panel.
https://www.facebook.com/StateCollegeHomeInspector
http://www.centreinspection.com
Centre Inspection Services proudly serves the following towns; State College, PA 16801, Bellefonte, PA 16823, Centre Hall, PA 16828, Spring Mills, PA 16875, Millheim, PA 16854, Boalsburg, PA and the surrounding areas.
Old 8/12/11, 3:44 PM
Jim Port Jim Port is offline
Unmoderated Guest
In a cable assembly it is still code compliant to re-identify the white as a hot conductor. In conduit you would need to use the proper colors for the hots.
Old 8/12/11, 4:11 PM
With a 10/3 conductor. But there's no neutral connection on the water heater just a ground. So if you use a 10/3 what do you do with the neutral?
Hays, KS 67601
785-656-0272
Old 8/12/11, 4:16 PM
So if running the conductor from the disconnect box to the WH in a conduit, you would need to use 10/3? But again, what do you do with the white neutral since the WH only has 2 hots and a ground?
Hays, KS 67601
785-656-0272
Old 8/12/11, 5:06 PM
Two hots and a ground in any form (within reason).
If you use 10/3 the black and red are the hots, the white or bare is the ground.
Simply snip off the excess wire--or pull it all the way out of the cable--or wrap it in a jar of jelly--anything you want to do with it, so long as you have the three wires.
Old 8/12/11, 5:37 PM
Unmoderated Guest
You would just use 2 blacks and a green.
Using 10-3 would be a waste of materials. It could be used. The white would just be unused.
Old 8/12/11, 5:38 PM
Unmoderated Guest
The bare would be the ground, not the white. Grounding conductors need to follow the color convention required by Article 250.
Old 8/12/11, 7:03 PM
I found this on the iNACHI electrical course under the 240 Volt termination section:
"Since adoption of the 1996 NEC, all 240V circuits are required to be 4-conductor assemblies carrying:
  • two 120V ungrounded (hot) conductors;
  • one grounded (neutral) conductor; and
  • one equipment grounding conductor."
Any thoughts on that?
Also, why doesn't an electric water heater use a neutral?
Hays, KS 67601
785-656-0272
Old 8/12/11, 7:27 PM
Unmoderated Guest
That info is only dealing with circuits used for ranges and dryers that are actually 120/240v loads. It would help if it were clarified that it was talking about a 120/240 circuit.
A straight 240v load like a heat pump, AC compressor or a water heater do not require a neutral so 2 hots and a grounding means are all that is needed.
Old 8/12/11, 10:56 PM
Thanks Jim. Why don't those appliances (heat pumps, ACs, electric water heaters) utilize a neutral though? How do their uses of electricity differ from other appliances, like a stove, that are 240V but do use a neutral?
Hays, KS 67601
785-656-0272
Old 8/12/11, 10:59 PM
Robert Meier's Avatar
Thanks Jim. Why don't electric water heaters utilize a neutral though? I'm still having a hard time wrapping my mind around that one.
Because they operate at 240 volts. The neutral would only be needed if something were operating at 120 volts.
Old 8/12/11, 11:03 PM
Unmoderated Guest
Items like timers, dryer motors and lights are all 120 volt and need the neutral. Water heaters, AC compressors do not have anything that needs a neutral.
Old 8/13/11, 1:13 AM
David A. Andersen's Avatar
Kenny you better take the electrical course before Nick sends you an email...!!
BPI# 5015804
Old 8/13/11, 9:31 AM
Thanks David. That was one of the first courses I took when becoming a member and have referred back to it several times.
The NACHI course and the other electrical books I've read all indicate that electricity seeks to complete a continuous circuit. Supply through the hot (ungrounded) conductor, to the fixture where it completes a task, and then back through the neutral (grounded) conductor.
I'm sorry if it's a dumb question. But again, if 120V fixtures need the neutral path to allow current back to the panel why don't 240V fixtures? Or am I just thinking about it wrong?
Hays, KS 67601
785-656-0272
Yea or Nay- Tankless Electric Water Heater nwagner Plumbing Inspections 17 11/27/08 11:29 AM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
