Just the book I need. ha. ha.
Since this area is Square D mostly, I thought this was pretty interesting. After all, I have used PC's for Dummies in the past and was great. http://www.dummies.com/WileyCDA/Dumm...e/id-4797.html ![]() ![]() ![]() ![]() ![]() ![]() Keeping to Code: Choosing a Circuit Panel and Distribution Panel LocationAdapted From: Wiring Your Digital Home For Dummies When installing electrical service in your home, you should carefully choose the circuit panel that meets your needs and follows the electrical codes. Manufacturers produce residential circuit panels in various sizes, including 100-, 125-, 150-, and 200-amp versions. The 100- and 200-amp panels are the most popular. You must also follow the required building codes when choosing a distribution-panel location. Choosing a circuit panel It is usually cost-effective to choose a 200-amp panel, especially if you envision a lot of electrical expansion in your home later. The 100-amp panels have a maximum of 32 circuit-breaker spaces, and the 200-amp panels have up to 40 spaces. These panels are equipped with a main circuit breaker; if the panel's main breaker turns off all the power in the residence, or if it's one of up to six such panels in a group that does it, it must be marked as a service disconnect. If they're sub-panels, a MAIN marking label is appropriate. The electrical code limits the number of circuits in a panel to 42. For a single-phase system, if more than 40 spaces are required, you must install more panels. The largest three-phase panel has 42 circuit spaces. The code also requires that all power be turned off with no more than six hand operations. Additionally, these disconnects are required to be grouped for one occupancy, such as a single-family home or an apartment. Figure 1 shows a Square D 200-amp 40-circuit panel. Over the years, many manufacturers and styles have come and gone, but Square D uses the same breaker and panel style that they introduced many years ago. A new Square D breaker made today will fit in panels that were installed 40 years ago. ![]() Figure 1: Square D circuit panels have changed little over the years. Very large houses commonly have panels in scattered locations. By code, the disconnects for these remote panels must be grouped and marked as service disconnects, and each disconnect must be marked for the location it serves. At some accessible location inside or outside the home there must be one to six marked service disconnects that turn off all the power to the home. The main breakers in any remote panels shouldn't be marked as service disconnects. They must be marked with information that states from what source panel they're fed. Choosing a distribution-panel location Your distribution panel should be somewhere both safe and convenient. It should not be blocked by obstructions, not only because you need to access it easily during installation and maintenance, but also because you may need to access it quickly in an emergency. Building codes make the following requirements for panel location:
The power company usually overfuses the service-entrance conductors. Their fuse is sized to protect their transformer, not your service-entrance conductors. If your service-entrance conductors become shorted, they're likely to burn before the power company's fuse blows. Code considers service-entrance conductors to be outside of the building if they're encased in 2" of concrete. In a basement or on-slab construction, you can run the conductors below the slab to a central location remote from the meter location.Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
lol....dont tell me that panel is the poster boy for that book, if so it lost all creditworthyness. Guess those connectors are designed for more than (2) cables....lol
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Glad I didn't write the book Paul.
lol....naw..heck probably much better than I could write anyway so all is good.
Problem is I am not sure I want " Dummies " doing electrical work in the first place.... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Paul
There is a possibility those fittings may be listed for more than 2 cables. I have seen some listed for quite a few. Those are larger than 1/2in though. One item sticking out like a sore thumb is the bending radius of the supply conductors. They are most likely 4/0 Al. If so, Table 312.6(A) would require 4 inches of bending radius, which that panel does not have. |
Paul, are those plastic romex connectors legal bunched like that? Assumming they are stapled 12" above the panel?
Curious, and I agree, I would not want Electrical Dummies working for me either. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I hardly think even a 3/4" or 1" plastic click is rated for what I see in that picture. I think I count ( eight or more in one of them and knowing the largest ko on that side of the main KO is probably 3/4" or 1"... I dont believe in my inspecting around Virginia's Capitol I have seen any rated for that many...sorry. Also I dont believe I see the "white" conductor in that panel on the 2-pole breaker to the lower left as being re-identified. Alas.....a poor picture to use as a publication on how it should be done. I am sure someone could stage a better picture of a panel if they wanted. Guess it depends on the publication of the book on the re-identify issue...still a poor picture to use. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
The real electrical for dummies:
Now that book simply does not exist...Marc have you been practicing with PaintShop Pro lately.
Does the pink tu-tu cover that pink thong? Now where is that picture? Oh that's right, I sent it to the Richmond mayor..... Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 2:14 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 2:48 AM |
