How effective would this set-up be? The ground strap across the meter is OK. Just wondering how good is the plastic supply pipe is for a conductor. THe house is 8 years old.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
How was the servoce equipment grounded? |
Exactly why an earth-ground rod is required and the copper water pipes inside the house should be bonded.
I bet there is a ground rod outside and the water bonded nearer the panel.
The meter was likely jumped out since the NEC tells us to when the pipe is used an electrode, which this pipe is obviously not. See how it is just a jumper, and not a GEC (grounding electrode conductor). Either it is just for looks, or some dopey inspector made the contractor install it. |
In this case, there was an addition grounding lead that went through the service conduit to the exterior of the home. Unfortunately, I could not see the termination since it wasn't exposed on the exterior.
The installer is not a plumber he has taken a quick course on how to do the meter install he has no idea what the reason for the ground jumper is he is just doing as told. Our town did not have meters and after 30 years they had a company put in the meters. Some instillations are humorous Cupboards doors that can not be opened example. Low price got the job. Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
IMHO, that doesn't look like 'grounding' just bonding all piping around removable items, like meters and water headers.
I don't see any grounding wire from the service panel, so this is why I made this comment. Quote:
tom |
There was nothing exposed (service lateral) on the exterior of the home. I did attach a pic of the panel but it doesn't show the conductors exiting the panel.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In Last edited by gliebig; 12/19/06 at 8:54 PM.. Reason: Picture was not attached |
From the latest photo, it's oke that there is a conductor going to the copper piping, it's now bonded, but I don't see any grounding in the panel.
With the presence of the bonding screw, there is one or another problem here: 1. No grounding. 2. Grounding at the meter base, and possibley an improperly installed service panel. Defently refer this so a qualifed electrician. tom |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
