We found an electrical outlet that is less than 12 inches next to the sink in the Laundry room. It is not GFCI protected. What is the standard for this.?
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would recommend a gfci outlet be added for safety
Thanks, That is what i thought.
Under the 2008 NEC it is required to be GFCI protected. This was added to the 2005 NEC.
Agree with James.
Alabama Home Inspections www.thebirminghamhomeinspector.com Home Inspections in Birmingham, Montgomery, Huntsville, and Tuscaloosa. |
Agree
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Hi Annette!
Hope you're well, haven't seen you in awhile. Great resources for stuff like that here.. http://www.nachi.org/education.htm You or your husband can always call me too! Tim |
Remember - As an HI you are concerned with SAFETY and yes indeed recommend GFCI protection. As for the NEC. this requirement came into effect in the 2005 NEC so prior to that it was not required...just remember that in how you write up your report. Be sure to imply it as a safety enhancement versus saying it is a code requirements as again, prior to the 2005 NEC is was not a violation.
Paul W. Abernathy |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 1:14 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 1:48 AM |
