Does anyone have the actual NEC code reference regarding the clearance from center of panel for working room? I am not at the office where my code book is at and need it? also maybe a picture as well ?
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The panel requires a 36" deep x 30" width.
110.26(A)(2) The width of the working space in front of the electric equipment shall be the width of the equipment or 750 mm (30 in.), whichever is greater.
Thanks, Jim and Jeff. I new what the code was I needed the code refference, Jeff you were right on que, thanks. Left my code books at the office and needed the refference.
There is working clearance and then there's dedicated space requirements. Here are some graphics of each from the NECH:
Dedicated space: ![]() Working space:
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Electrical Safety Foundation International Links | jtedesco1 | Electrical Inspections | 5 | 12/8/07 3:10 PM |
| Handbook for Electrical Safety | pabernathy | Electrical Inspections | 1 | 1/1/07 1:14 PM |
