Old 9/15/06, 9:40 AM
csteele csteele is offline
Default Electrical Panel Installation
I'm sure I read before that the electrical panel must be installed on a non-flamable material such as drywall. But I think there were exceptions.
Can anyone tell me if it is true the panel must be installed on non-flamable material and are there exceptions? I suppose it would be different in ever state, but up here in Ontario Canada I'm sure there is a requirement.
Old 9/15/06, 10:33 AM
Rob A. Parker Rob A. Parker is offline
Send a message via ICQ to rparker
Default Re: Electrical Panel Installation
Chistopher I believe it was a requirment some years ago for the panel to be installed on a non flamable material ,but I also believe that the requirment was drop just a few years ago
Rob Parker RHI CMI
ITC Level 1 Thermographer
Thamespec Inc.
www.thamespec-inspections.com
Old 9/17/06, 4:16 PM
Good question....now personally I install every panel on treated plywood because it looks nice and professional having the NM Cables stapled to it as they come down and into the enclosure.
But I do not recall it being a requirement per say.....now many mount panels directly to block walls and the panels are made in such a way they have a 1/4" stand off for air circulation and so on.....but in regards to the mounting on plywood.....not sure it is a big problem.
Paul W. Abernathy
Old 9/17/06, 5:56 PM
Unmoderated Guest
Must have been a Canada thing. I have never heard of this.
All my masonary mounted panels are on plywood as Paul does, only I use A-C.
Also, how many panels have we all seen mounted to the framing of finished walls? It doesn't get much closer to flamable than that.
Old 9/17/06, 6:17 PM
Doug Edwards's Avatar
Doesn't do much good if they insist on mounting it above the clothes dryer and it is full of fine lint. Lint is an absolutely excellent emergency fire starter. Find panels in the laundry rooms are often full of it too.
- John Stuart Mill
Old 9/17/06, 6:39 PM
Unmoderated Guest
Especially when used inside a dryer.
Old 9/17/06, 9:53 PM
William J. Decker's Avatar
Ewwww! You use NM for wiring raceways? How barbaric!
haven't you ever heard or EMT?
PLEASE NOTE; This is just 'chain pulling' of a friends.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 9/18/06, 8:34 AM
lol......WHAT........we are LESS barbaric because we use MODERN cable other than that "HARD METAL PIPE" you guys in that freakish state use...thehehehehehhe
Now see here Monkey Avatar fellow...lol......you know somethings up when 95% of the US allows NM Cable and Illinois does not......can you say...Capone..?
Me pullin back at your chains my fine fellow....
Paul W. Abernathy
Old 9/18/06, 8:37 AM
rwand1 rwand1 is offline
Chris
The requirement as Rob alluded to was dropped sometime ago by ESA.
Old 9/18/06, 8:40 AM
Paul;
I understand.
The fine art of EMT bending is a subtle thing. Well beyond most electricians grasp.
Will Decker, CMI
Old 9/18/06, 8:45 AM
lol......I bent that stuff up to 4" for nearly 12 years of my career.....I was GLAD to leave that "subtle thing" years ago...lol....
From the good ole Benfield Bender to the Hydralic Bender......my PIPE luggin days are over.....thehehe
Paul W. Abernathy
Old 9/19/06, 9:19 AM
brepanshek brepanshek is offline
Please Note: brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Paul what are the requirments for fastening wires, the distance from where wires enter/exit the main panel? What I mean is that if the panel is mounted on a masonary wall about 4 feet from the ceiling, the incoming and outgoing wires need to be secured ( what 12" from box?) without plywood like you use behind your installs to fasten wires to what should I see for proper fastners for when mounted to block only?
Old 9/19/06, 9:30 AM
Brian,
If you are speaking of NM Cable then you should always see the cables going into enclosures via a connector for support and retention and the wires need to be fastened within 12" of the enclosure. Section 334.30
Block or plywood the support requirement is still their.....
Note: their is an exception for single gang non-metallic boxes just in case anyone wants to know...no cable securing means are needed if stapled within 8" of the box.....but I wont dable in that..if anyone wants to review the exception check out Sec 314.17(C)Ex
Paul W. Abernathy
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
