| View Poll Results: Do you shut off electrical service components ? | |||
| No I never do that |
15 | 28.85% |
| Yes every time |
1 | 1.92% |
| Only when I suspect something |
5 | 9.62% |
| Only AFCI and GFCI test buttons |
31 | 59.62% |
| Voters: 52. You may not vote on this poll | |||
When performing Home Inspection do you consider it part of your job to trip breakers ,throw Mains ,and pull cartridge fuses as routine ways to examine and report on components ?
If you do it sometimes you should do all of them and every time , but please explain why not if you disagree. I feel you should only test AFCI and GFCI buttons. Tell me how you feel and why. Maybe you can change my mind. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 7/21/10 at 9:42 PM.. |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Sure....... when inspecting my own house.
GFCI AFCI
If I had to shut the power off to inspect a component I would going beyond what I am paid to do. |
I pretty much agree however some feel we should be flipping all power equipment switches.
http://www.nachi.org/forum/f20/humming-ac-52439/ |
On a vacant house, I'll turn the main power off when I leave if requested.
I may pull a disconnect on an AC condenser if it's blowing hot air in my face. I may pull the disconnect on a furnace for a minute in the attic if I want silence to trace a bathroom ventilator, for example. That's about it. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I never do any of those things.
But I will pull the handle on the A/C equipment disconnect to check for signs of conductor overheating, grounding connections and line/load connections, but then you already know that. Do you even check for the presence of a disconnect? Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 7/21/10 at 11:14 PM.. |
I choose NO......i wont group the AFCI and GFCI within the rhelm of turning off the service to the structure. The SOP calls for the AFCI and GFCI to be tested but not to disconnect the main...if that is what you are asking.
Paul W. Abernathy |
I've never heard of such a thing! Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 7/21/10 at 11:25 PM.. |
Silly question since having a disconnect at the compressor equipment is required and nobody here would cop to not noting or observing the absence of required material items. We are all professional I hope. As far as the survey goes I just want to get it straight that no one is going around flipping all the breakers and if they are I want to know why and how many are. Chuck aren't you also curious as to the responses? |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bob, Where did that come from? No one ever stated that. I do not shut off or reset tripped breakers, there are shut off or tripped for a reason. I test GFCI's with the button and/or tester at GFCI only. I ONLY push the test button on AFCI's in vacant homes. Been there done that in ocuupied home and heard the dreaded "My computer just shut off, what the h#ll did you do?" and that is not gonna happen again. I do however pull every fuse block and removed the dead front from every AC disconnect (not running or under load) to check wiring and fuse size. I also do this on every spa disconnect for same reason. In about 60% of the AC disconnects there are either wiring problems or improper sized fuses. Yesterday the AC disconnect was missing the ground wires and the AC nameplate called for a max 40 amp fuse and the fuses installed were 60 amp. Chuck Last edited by Chuck Lambert; 7/22/10 at 1:53 PM.. |
Should you not also pull other disconnects? |
The only disconnects we see out here are for the AC condensing units, electric spas, we do not have fused disconnects on furnaces. When doing pools and spas the timer gets opened and the wire cover comes out (most are broken or missing)to check wiring in them also. If the pool equipment has the control center type sub panel built in the dead front comes off of those also. I do pull the dead fronts on all main and sub panels even the dreaded Zinsco and FPE panels (well all but 2 or 3 in 10 years). Chuck |
What if you have a fused main panel with cartridge fuses behind the pullout. Do you pull the main or not and if not how is that different ? I am expecting you to say it is because that is only one system component at the A/C but it seems it would be even more important to check the main panel to be sure there is not an inside the home danger. OH ,I never pull FPE or Zinsco as a general rule since I have run into some of them with loose breakers and I think it would be best to have an Electrician certify them as OK.If you feel comfortable doing so , knock your socks off but do not jump out of your shoes. Seriously the best way to check them may be to physically give them a wiggle and sometimes that appears unsafe. |
Fused mains on a vacant house I will pull, occupied no. There are not that many fused mains here in California as insurance companies tend to not like them. The ones that do exist here and I have run across I have been able to see the labels on the fuse. Fused mains are mostly on commercial around here, same for that vacant I will pull, occupied no. Pulling a main fuse on an occupied property would shut all electrical systems down same a tripping the main breaker. I will not do that. As to the Zinsco and FPE's they can be a hair rasing experience. I have found that the Zinsco's are easier to deal with than the loose FPE's. Chuck |
OK so basically you do not pull mains for the same reason I do not pull covers off FPE.
More of a risk factor. Got ya. |
| Quick electrical question. Need fast! | wdecker | Electrical Inspections | 6 | 3/21/10 10:13 PM |
| Electrical box question - posted by weary parent | Unregistered | AskNACHI.org Inspection Questions Forum | 0 | 5/29/09 8:45 AM |
| Electrical Question | mkyriacou | Exterior Inspections | 9 | 3/12/09 2:59 PM |
| Download the videos here all about physics and electricity | jtedesco1 | Electrical Inspections | 5 | 9/14/08 3:58 PM |
