| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Just remember that service equipment can have circuit breakers or fuses as well. Also in many older panels with poor connections due to oxidation in the case of a aluminum buss bar of a zinsco...you may also hear arching as well and could be a sign of problems.
In some panels be it old and new, the physical contact points of the OCPD to the contact point of the buss may not be making good contact which will generate an arch which over time will increase in heat and become a potential fire hazard to be aware of. This can come from improperly listed devices in the panels as well or over time due to age where the tension of the contact points weaken. Paul W. Abernathy |
How can inspectors check for that? Thanks Paul Researcher and Technical Writer, InterNACHI |
Inspectors can check for the following defective conditions during an electrical panel inspection:
1. Why is Zinsco called out but not Federal Pacific?
2. "Circuit breakers should not be too large or too small for the wires they serve" - should be made clear this refers to the electrical characteristics, not the physical. 3. "While removing the panel, inspectors should" - should say 'panel cover' or 'deadfront'. Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog Last edited by mboyett; 1/7/10 at 9:27 AM.. |
I don't see anything about even basic protective equipment like safety glasses.
We call out both Zinsco and Federal Pacific panels. But you have to be careful. Neither of these panels was recalled. They are just the subject of debate, with evidence that they are unsafe.
If you say it was recalled and "must" be replaced, you could end up paying for it. Just say that they have a reeputation of being problematic. Recommend further eval. Philippe Heller The San Diego Real Estate Inspection Co. http://www.sdinspections.com www.facebook.com/sdinspections |
Paul W. Abernathy |
You can hear it from the arching....makes a popping sound and crackling sound due to the gap an arch jumping across the poor contact points. You can also see this with an infrared temp. gun as well like i explained in the video I did for NACHI.
Paul W. Abernathy |
thanks guys
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
look for any nicked wires near the screw as this may reduce the ampacity and look for any aluminum branch wiring etc. should be added. T.N |
Nick, what about the presence of rodents or their damage. I have not seen that in any articles; but I have not seen it in a panel yet either. As far as damage, I have seen in one of my past homes where a rodent has chewed he insulation off of a wire down to the wire. Whatever it was that did the damage seemed to have a preference for the insulation, and amazingly was able to chew off quite a bit of it without getting electrocuted. At least, I did not see a dead animal around the damage.
lol...if you are not going to add our comments then why give them....lol
Paul W. Abernathy |
Made those additions.
Sometimes I lose track of an old "pleas proof" thread if no one has added to it in awhile and I'm more concerned with the newer ones. But you're right, I'll try not to let that happen. Researcher and Technical Writer, InterNACHI |
| Some good questions that always need answers | jtedesco1 | Electrical Inspections | 5 | 6/16/06 9:10 PM |
| Old electrical panels? | ysoltis | Electrical Inspections | 3 | 1/14/06 11:00 AM |
| Old electrical panels? | ysoltis | General Inspection Discussion | 2 | 1/14/06 10:58 AM |
| Old electrical panels? | ysoltis | Electrical Inspections | 0 | 1/13/06 11:38 AM |
