Old 3/16/06, 6:59 PM
David Nice's Avatar
David Nice David Nice is offline
Default electrical tape in panel
Though I have seen it plenty of times I wondered if it is proper when upgrading electrical to cover white wires with electrical tape to make them black when connecting to breakers. If course they don't want it to look like white wires are being connected where they shouldn't be but should they be pigtailing to black wire instead of just covering the white wire with tape?
David Nice
National Certified Inspection Services, Inc.
Wauwatosa, WI
http://www.nationalcertified.com
414-979-6900
President WiNACHI
http://www.winachi.com
Wisconsin InterNACHI Chapter
Old 3/16/06, 7:08 PM
Jeffrey R. Pope's Avatar
Default Re: electrical tape in panel
Permanent reidentification.
Personally I don't think black tape is permanent, but apparently most AHJ's are okay with it. However, pigtailing (IMHO) is a bit extreme.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/16/06, 7:09 PM
Michael R. Boyett's Avatar
Black/red tape is fine by me. I'll be surprised if there's a legitimate argument against that.
Old 3/16/06, 7:41 PM
David Nice's Avatar
Cool!
David Nice
Wauwatosa, WI
414-979-6900
President WiNACHI
Old 3/16/06, 7:54 PM
Robert J. OConnor's Avatar
Tape is commonly used in commercial applications to identify wires, but it's not that common for residential work. I guess the sparky didn't have a nice fat sharpie ...
Keep in mind that the ends of that wire need to be re-identified wherever it becomes visible (feed-thru/splice boxes, termination, etc.) ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 3/17/06, 10:41 AM
TidBits - Re-identifying the white wire in a cable like NM,AC and MC will allow simply taping BOTH ends to permanently re-identify ( 200.7(c)(1) ) but for those in Chicago and other areas that use conduit...remember you can NEVER use white as a ungrounded conductor...regardless of re-identifying it...Just a little tidbit for you...
Paul W. Abernathy
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
