maitai11 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Guys, I hope I'm not dredging up anything with this one...it is a genuine question.
Stapling of wires on garbage disposals and hot water heaters. I think I'm seeing double vision here...I know it's required to be secured, but NOBODY DOES IT...Should I keep noting it? Or is it being nit-picky? Also, What is the maximum length of wire that one can go without stapling? Thank you in advance gentlemen... Maitai |
You can do short whips with flexible raceways or type AC but there is really no legal way to do it with Romex.
I also understand it is done every day. I would write it up but if it really didn't look like it was being damaged I might not hit it too hard. |
Max on Romex is 12" from the box and 4' along a run
Not to nit pick, but it is 4½ feet.
What about in the attic where it is never, ever secured?
smcarthur is a non-member guest and is in no way affiliated with InterNACHI or its members.
4 1/2' in the attic too.
The less accessible the attic area the less you worry about strapping and damage. In these 3:12 attics we have here I wouldn't worry about anything 6' from the hole unless the air handler was up there. (Bad idea in itself)
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Information from the Old Boards-NEC | pabernathy | Electrical Inspections | 1 | 7/17/06 6:34 AM |
| Some good questions that always need answers | jtedesco1 | Electrical Inspections | 5 | 6/16/06 10:10 PM |
| Electrical Safety Information | jtedesco1 | Electrical Inspections | 0 | 2/19/06 2:48 AM |
