At a listing inspection I noted at "sub" panel that grounds/neutrals need to be separated at bus bar, with neutrals isolated from panel.
First photo is before, 2nd is after repairs. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
LMAO........thats some funny stuff!
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Your fault Chris...you're the one that said they had to be seperated...
Wow, the repair looks more unsafe then the original installation.
Title had me fooled....I thought the Electrician repaired the maid...
What would be the easiest way to salvage this mess?
The EGC's can be spliced and pigtailed to the bus as long as the tail is the same size or larger than the largest conductor in the splice. Also the wirenut would need to be listed for the number of condcutors spliced together. So maybe you would need to combine all of the EGC's into two or three groups. Otherwise a simple ground bus bolted to the enclosure could be installed for all of the EGC's only. The neutrals need to be installed in a separate hole for each conductor in the neutral bus.
This is a case of redo and start all over again.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Can't believe someone went to all the trouble they did removing the EGC's from the bus, twisting them, and then reconnecting them to the same bus with an individual wire. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Wow! so what's with all the extra wire nut splices? I think who ever did this made it worse. Guess all you can do is report that is not done correctly, recommend rework/repair again, and hint that they should report this guy to the electrical board. I bet he was not a licensed electrican but a helper who works for a licensed electrican.
---I need to save that picture....once in a lifetime----------- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Hmmmm .... maybe installing a new ground/neutral bar would have been helpful ...
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 8/7/11 at 12:44 AM.. |
David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
| Home Inspector law suit | rcooke | Canadian Inspectors | 0 | 2/18/10 11:48 AM |
| Repairs made by a LICENCED electrician | cduphily | Electrical Inspections | 45 | 1/13/08 3:09 PM |
