Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 12/11/07, 9:54 PM
Post Are electricians supposed to use these tools as per 70E?
This Electrical Insulated Tool Kit is a deluxe maintenance Tool Kit with tool box. It Includes: 9/64 x 2", 3/16 x 4-1/2", 1/4 x 6" slotted screwdrivers, #1 x 3", #2 x 4" Phillips screwdrivers, 9" linemans pliers, 7-1/2" diagonal-cutting pliers, 8" needle nose pliers, 3/8"-drive reversible ratchet, 3/8"-drive x 3" and 6" extensions, eight-piece 3/8"-drive 12-point socket set (3/8 - 13/16"), eight-piece box-end wrench set 3/8 - 13/16"), 30 - 150" torque wrench and a mini flashlight. These tools comply with IEC 900, NFPA 70E, OSHA 1910.333(c)(2) and exceed ASTM 1505 standards for insulated hand tools. Tool Kits are tested to 10,000V AC and rated for use up to 1000V AC. Made in the USA.
Features:
  • Use up to 1000V AC
Old 12/11/07, 10:04 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Are electricians supposed to use these tools as per 70E?
I used to go in panels with stuff from the one dollar tool bin.
Looks good to me.
Old 12/11/07, 10:22 PM
William J. Decker's Avatar
William J. Decker William J. Decker is online now
Remember that national codes are not always (or usually) adopted by the local AHJ.
This post refers to NEC "recommendations" to help the electrician (if he is smart and doesn't want to kill himself) keep himself safe.
Not a "requirement", just a "helpful hint".
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 12/11/07, 10:35 PM
See NFPA 70E
NFPA 70E Standard for Electrical Safety in the Workplace 2004 Edition
ARTICLE 90 Introduction
Chapter 1 Safety-Related Work Practices
ARTICLE 100 Definitions
ARTICLE 110 General Requirements for Electrical Safety-Related Work Practices
ARTICLE 120 Establishing an Electrically Safe Work Condition
ARTICLE 130 Working On or Near Live Parts
TIA
Chapter 2 Safety-Related Maintenance Requirements
ARTICLE 200 Introduction
ARTICLE 205 General Maintenance Requirements
ARTICLE 210 Substations, Switchgear Assemblies, Switchboards, Panelboards, Motor Control Centers, and Disconnect Switches
ARTICLE 215 Premises Wiring
ARTICLE 220 Controller Equipment
ARTICLE 225 Fuses and Circuit Breakers
ARTICLE 230 Rotating Equipment
ARTICLE 235 Hazardous (Classified) Locations
ARTICLE 240 Batteries and Battery Rooms
ARTICLE 245 Portable Electric Tools and Equipment
ARTICLE 250 Personal Safety and Protective Equipment
Chapter 3 Safety Requirements for Special Equipment
ARTICLE 300 Introduction
ARTICLE 310 Safety-Related Work Practices for Electrolytic Cells
ARTICLE 320 Safety Requirements Related to Batteries and Battery Rooms
ARTICLE 330 Safety-Related Work Practices for Use of Lasers
ARTICLE 340 Safety-Related Work Practices: Power Electronic Equipment
Chapter 4 Installation Safety Requirements
ARTICLE 400 General Requirements for Electrical Installations
ARTICLE 410 Wiring Design and Protection
ARTICLE 420 Wiring Methods, Components, and Equipment for General Use
ARTICLE 430 Specific Purpose Equipment and Installations
ARTICLE 440 Hazardous (Classified) Locations, Class I, II, and III, Divisions 1 and 2 and Class I, Zones 0, 1, and 2
ARTICLE 450 Special Systems
Annex A Referenced Publications
Annex B Informational References
Annex C Limits of Approach
Annex D Sample Calculation of Flash Protection Boundary
Annex E Electrical Safety Program
Annex F Hazard/Risk Evaluation Procedure
Annex G Sample Lockout/Tagout Procedure
Annex H Simplified, Two-Category, Flame-Resistant (FR) Clothing System
Annex I Job Briefing and Planning Checklist
Annex J Energized Electrical Work Permit
Annex K General Categories of Electrical Hazards
Annex L Typical Application of Safeguards in the Cell Line Working Zone
Annex M Cross-Reference Tables
Tentative Interim Amendment
Index
Old 12/11/07, 10:47 PM
Post Re: Are electricians supposed to use these tools as per 70E?
For the Commercial Inspector who will inspect electrical systems in those types of buildings.
Do you or, will you follow these rules?
Courtesy: NFPA, NEC 70, 110.16
Old 12/11/07, 11:03 PM
relliott's Avatar
I know some people that might wear that for changing a light bulb.
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Joe,
I provide a comprehensive safety guideline in my commercial inspection class. Bottom line is that all commercial inspections are not the same. The fact that anything EXCEPT a structure with 4-dwelling units or less is commercial, classifies all else as commercial property. The key to all of this is self-assessment and bring a SME along where needed. The NEC is nice, but is also cvoluntary when it pertains to the areas you point out. If a fool wants to electricute himeself, he will figure out a way to do it.
Old 12/11/07, 11:40 PM
Gerry Beaumont's Avatar
Gerry Beaumont Gerry Beaumont is offline
Originally Posted by jfarsetta
Joe,
I have to agree with Joe F here, the systems that home inspectors are generaly rated 240V, safety is good, overkill is non productive.
Joe T, you have much to offer here please keep it relavent to home inspectors looking at 240V systems.
Regards
Gerry
Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience.
Adam Smith (1723-1790)
NACHI cell 484-429-5466
NACHI02121106
Old 12/12/07, 2:03 AM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
I noticed there are some references to the NEC.
OSHA really has the pervue here.
The determination is not the voltage, but whether or not one has employees. A self employed person does not have as much to be concerned about in relation to most OSHA requirements.
Old 12/12/07, 2:18 AM
relliott's Avatar
Pierre as far as your comment go's I must dis-aggree as I know there have been many self employed contractors fined by OSHA.
They will go after a self employed contractor just as easily.
You just may not hear about it as much.
Old 12/12/07, 7:47 AM
Regards
Gerry
Thanks Gerry, I guess that we should try to define those commercial buildings or locations that do not fall within the commercial inspection areas, such as: marinas, repair garages, fuel dispensing facilities, banks, clinics, hospitals, theaters, offices, hotels, restaurants, assembly occupancies, or similar areas. I searched the NEC and found many references to commercial areas that were in my thoughts.
My 70E reference here was not implying inspections of the areas identified in the contents. The scope of 70E reads as follows:
"Document Scope: (A) Covered. This standard addresses those electrical safety requirements for employee workplaces that are necessary for the practical safeguarding of employees in their pursuit of gainful employment. This standard covers the installation of electric conductors, electric equipment, signaling and communications conductors and equipment, and raceways for the following: (1) Public and private premises, including buildings, structures, mobile homes, recreational vehicles, and floating buildings (2) Yards, lots, parking lots, carnivals, and industrial substations
FPN: For additional information concerning such installations in an industrial or multibuilding complex, see ANSI C2-2002, National Electrical Safety Code. (3) Installations of conductors and equipment that connect to the supply of electricity (4) Installations used by the electric utility, such as office buildings, warehouses, garages, machine shops, and recreational buildings, that are not an integral part of a generating plant, substation, or control center."
Old 12/12/07, 8:44 AM
I found the definition in the:
"International Standards of Practice for Inspecting Commercial Properties
2 Definitions
2.1 Core definitions
2.1.1
Commercial Property - A commercial property is defined as the building structures and improvements located on a parcel of commercial real estate. These may include structures such as buildings with residential units operated for profit, mixed use buildings, strip malls, motels, factories, storage facilities, restaurants, and office buildings."
Old 12/12/07, 9:06 AM
Hi to all,
Joe, NFPA 70E covers installation of conductors, as apposed to non invaisive inspection, also the deffinition of commercial property that you quote from NEC and ASTM is not what most of our members inspect, remember that our standards, and those covering inspectors in licensed states generaly define Home inspection as a limited visual non-invaisive evaluation of a single family property or a residential building containing 4 or fewer residential units.
Regards
Gerry
NACHI02121106
Old 12/12/07, 9:15 AM
Hi to all,
Regards
Gerry
Gerry:
I found the definition here:
Old 12/12/07, 9:26 AM
Originally Posted by jtedesco1
Hi Joe, appologies, I was just checking ASTM 2018 for that verbiage when you posted, no wonder I couldn't find it!!
Regards
Gerry
NACHI02121106
Interview for Lowes Pro's pabernathy Electrical 2 12/10/07 10:18 PM
Stolen Tools... bnelson General Inspection Discussion 31 12/21/06 5:43 PM
Must have tools for HI gkoehl General Inspection Discussion 13 9/4/06 4:26 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
