Thought you guys would like to have some fun with this. What DONT you see wrong.
774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What do you see wrong besides the apparent damage to the insulation in photo #2?
Are those panels mounted sideways or are your photos?
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Do you like the way the service junction box is supported? Do you like the cover on the box? Do you think the double tap on the breaker is okay?
Which (if either) of those panels is the service equipment? The neutrals are bonded to the boxes at both panels.
This was a 3 family, 3 separate main panels and 2 of the panels had sub panels at the living level. I didn't post all the photos.
No, sorry Mark, I looked at the wrong photo. This pic shows all 3 panels. The one on the left is the main panel with individual circuit breakers for one apt., the other two are main panels that feed sub panels at the other 2 apartments.
How would one know if the cover was on the box if your photo was depicting what's inside the box? Now that you've mentioned it the support is pretty lousy. I can't see any double taps on the CB's but that could be because of the photo quality.
Is the double tap on the main breaker a problem?
Yes, and why is there only 120 volt hooked up? Are those unused feeds live?
www.MauiHomeInspections.com |
OK now I see it. Yes that is a problem. Not sure why someone would do that. Could lead to a huge problem since all of those 3-wire MWBC's will be on the same phase sharing a neutral. The neutral load could be up to 40 amps if those two circuits were protected at 20 amps each.
| Disaster Inspectors!! | gheidepriem | Miscellaneous Discussion for Inspectors | 0 | 8/30/07 10:25 PM |
| Free Online Calculators - Enjoy ! | pabernathy | Miscellaneous Discussion for Inspectors | 4 | 12/27/06 8:54 AM |
