Old 2/28/07, 9:55 AM
dsmith1 dsmith1 is offline
Question Entrance
Home is 2 years old and part of a row of 6 townhouses heated by water source thermo pumps. The main shut offs and panels for each are rated 200 amps. The main shut off for all is labeled at 600 amps. Does this seem OK?
Old 2/28/07, 10:40 AM
Harvey Gordon's Avatar
Harvey Gordon Harvey Gordon is offline
Default Re: Entrance
Are you saying that you believe that 200 x 12 units should be 1200AMPS?
Harvey Gordon
- President -
FloridaNACHI
(The OFFICIAL Florida State Chapter of NACHI)
SEFloridaNACHI
(Serving NACHI Members in Martin, Palm Beach, Broward, Miami-Dade, and Monroe Counties)
______________
Questions or Comments about FloridaNACHI or if you would like to start a LOCAL Florida Chapter may be sent directly to me at hgordon@fl.nachi.org
______________
Old 2/28/07, 11:22 AM
No, but it just seems 600 may be a little low.
Old 2/28/07, 11:23 AM
Jeffrey R. Pope's Avatar
Just answer the question Harvey
We can assume that the EE made the determination, based on load calcs, that 600 amps is sufficient for service to the building. It really doesn't matter what the individual unit disconnects are rated for as the two have little to do with eachother.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/28/07, 4:29 PM
Marc D. Shunk's Avatar
Banned
The steel bumper pictured, although likely installed with good intentions, is a violation.
Old 2/28/07, 5:05 PM
Unmoderated Guest
I know Marc. Pretty funny. I can imagine what that thing cost to intall too.
David, I just did a 4 pack meter with four 100a main breakers. The calculated load was under 200 amps for three apartments and a land lord space.
If I wanted I could have used a 200 amp riser.
Old 2/28/07, 5:36 PM
Michael Larson's Avatar
Marc, because of the workspace requirements correct?
Would that also apply to what I think is the original bollard(which looks short to me) in front of the left side cabinet?
Old 2/28/07, 5:50 PM
Brian E. Kelly's Avatar
Workspace yes, bollard looks more like the power comming in to me.
Old 2/28/07, 6:11 PM
Banned
Yep, that's a fact. If I was the electrician who had to service that installation, I'd have to unbolt that bumper from the Rawl studs and take it off the wall. That 600A Seimens disco may or may not contain fuses. I hope it doesn't, because that bumper will not permit the door to open 90 degrees, as required. That bumper is a big problem. No doubt about it. A better approach would have been a "cattle fence" that was set in sleeve pockets in the floor. Such a gaurd can be easily lifted up and out of the way.
That looks more like a red enameled or epoxy coated ell coming into that two door CT cabinet. Hard to say from the pic, for sure. I'm a little puzzled why they even have a CT cabinet. Are those landlord owned submeters? Maybe they were just thinking ahead, by installing the CT can.
Old 2/28/07, 6:14 PM
I enlarged the pic and I can now see that it is indeed an ell. Thanks Marc, you too Brian.
Old 2/28/07, 6:42 PM
Anything for you Michael. Piping is more in line with my past experience, but I do remember a time or two where the Electricians were in the way with some of those small wire thing-a-ma-bobs. ELL sounds like a lot better way to say it.
Old 2/28/07, 6:52 PM
tdietrich1's Avatar
I'm curious, the disconnect has a amperage rating of 600? Sure it wasn't volts?
tom
Old 2/28/07, 7:02 PM
Banned
tom
It probably was amps. Seimens is not my main brand, but those meter stack disco's have a big buss structure along the bottom that permit it to "plug in" to the meter stacks. That's what probably accounts for its unusual size appearance. It would be highly irregular to have a meter stack disco rated at more than 250 volts. That would be super-custom equipment, which this it not.
Old 2/28/07, 7:04 PM
Banned
The bumper still puzzles me.
Please tell me this service equipment is not installed in the garbage room or parking garage.
Old 2/28/07, 10:51 PM
Marc, it looks like it might unlatch and swing open.
Service entrance and a raised garden tjansson Electrical Inspections 18 9/7/07 8:47 AM
Service Entrance jcampbell Electrical Inspections 9 10/30/06 12:14 AM
New Entrance Exam inxil Miscellaneous Discussion for Inspectors 52 9/27/06 2:34 AM
Service Entrance Amps? dtaylor Electrical Inspections 12 8/5/06 3:38 PM
Service Entrance Amperage? jfunderburk Electrical Inspections 18 6/16/06 10:16 PM
