Need some clarification on these panels.
The first one was improperly installed to high and obstructed by a shelf/storage. The second one had some improper wiring practices. The main panel had improper access to safely remove the cover. I have some additional questions on this set up. It looks like a range/dryer wire going to the exterior air condenser disconnect. (This was also locked) Data on the air condenser was not readable. I get confused on the arrangement of a remote distribution panel or equipment over current protection. Any additional information on this setup would be appreciated. I differed to a sparky but posted for my benefit of learning. And if P.Abernathy is around I am enjoying your book but my name is Macy and not Macey. (A common misspelling) |
What a mess!
Those are "power cutoff switches with fuses" that have been daisy chained from one feeder (from the "main panel"). You have plenty going on there.. I love the fact that they used one set of feeder wires to handle the A/C disconnect (probably a shock hazard) and then feeding another set of receptacles. There are so many problems here it's a total repair / replacement by a qualified electrical contractor deferral. My question to you is what "set of fuses" blow first in this set up when both the A/C and the downstream receptacles are being used? |
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 3:00 PM |
| Download the videos here all about physics and electricity | jtedesco1 | Electrical Inspections | 5 | 9/14/08 4:58 PM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Where is it written.... | bgromicko | General Inspection Discussion | 18 | 1/19/08 10:02 PM |
| Dwelling and Commercial Electrical Equipment | jtedesco1 | Electrical Inspections | 4 | 1/10/08 7:46 AM |
