Old 6/30/11, 2:37 PM
Justin R. Ake Justin R. Ake is offline
Default Estimating Amperage
I was taught to use the lowest capacity device to estimate amperage. For instance, if the panel is rated for 100amps and the meter is rated for 200 amps, then the amperage is 100. Of course, the SE cables have to be considered too. My question is how to determine the amperage of the SE cables and the main disconnect. Typically the main will be labeled but what happens when the main disconnect is not labeled? How do we estimate that?
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/30/11, 9:21 PM
Sean Fogarty's Avatar
Default Re: Estimating Amperage
Mains are generally always labeled or the fuses for the main will have the ratings. WIies will also have marking to show gauge size. Every situation is different.
If you are ever not sure then you should take pics, do homework or disclaim you could not determine the amperage.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 6/30/11, 9:36 PM
Jim Port Jim Port is offline
Unmoderated Guest
As you gain more experience you should be able to visually gauge the wires compared to conductors and cables of a known size.
Old 7/1/11, 7:06 PM
Robert Meier's Avatar
You need to assess the conductor size and the Main OCPD size. It is possible to have over sized condcutors which would make the service ampacity the smaller of the two or the OCPD size. For most dwellings you could look at NEC {2008} Table 310.15(B)(6) and use that to find the service conductor ampacity.
Old 7/2/11, 2:05 AM
Robert J. OConnor's Avatar
Originally Posted by jake1 View Post
My question is how to determine the amperage of the SE cables ...
Based on type of wire and size ...
http://publicecodes.citation.com/ico..._36_sec003.htm
Basically ... #4Cu = 100a, #1 Cu = 150A, and 2/0 Cu = 200A. Try some plastic gauges if you dont have a good feel for wire size or cant read any cable markings.
You dont estimate it ... it's just an unknown ya have to deal with sometimes ...
See this link for a good discussion ... http://www.inspectapedia.com/electric/ElecAmps.htm
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Determining Voltage as well as Amperage of a Service twitt Electrical Inspections 10 6/30/11 2:36 PM
For New Inspectors doing Four-Point Inspection to dertermine wire size and Amperage apelletier Florida Inspectors 3 3/17/11 7:12 AM
service amperage tlemasters Electrical Inspections 1 3/20/10 1:51 PM
Amperage draw question jbreazeale Inspecting HVAC Systems 5 7/26/07 3:02 AM
Service Entrance Amperage? jfunderburk Electrical Inspections 18 6/16/06 10:16 PM
