Old 12/3/07, 6:18 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default Excused "Ganged Neutrals" from Electrician
Wrote up and kicked back... everyday it seems...
I clipped this from the pdf and didn't show his name...
Maybe he knows something different than
NEC 408.41 Each grounded conductor shall terminate within a panel board in an individual terminal that is not used for any other conductor. (Bold is mine)
Another day...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 12/3/07, 6:23 PM
Default Re: Excused "Ganged Neutrals" from Electrician
Picture too big.
His statement:
"The National Electric Code allows this wiring method in homes not required to have an outside disconnect. I checked all of the connections and they were tight"
Is he correct?
- Mike
NACHI05040682
(843) 442-9755
Old 12/3/07, 6:39 PM
Jeffrey R. Pope's Avatar
His statement doesn't make any sense.
This has no relevance to the issue of "ganged neutrals."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/3/07, 6:49 PM
Below is what I sent the client (buyer)
Here’s a picture to explain and a quote from the NEC and another to show why they should not share a lug…
A Grounded Conductor is a Neutral (White wire) a Grounding Conductor is a bare wire.
They’re not correct and his NEC ‘quote’ is wrong.
-Mike
- Mike
NACHI05040682
(843) 442-9755
Old 12/3/07, 7:15 PM
I would have omitted this part, but I agree with the rest of your assessment.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/3/07, 7:17 PM
My wife always says "Less is More"
or that I "Talk like a teenage girl on the telephone"...
Don't know where that came from; we have two grown sons...
- Mike
NACHI05040682
(843) 442-9755
Old 12/3/07, 7:40 PM
My bet is his reference to the outside disconnect was his way of saying this was not a sub panel and the grounds can be on the neutral bar. Maybe he doesn't know they codified the "individual terminal" language for grounded conductors in 2002. Plenty of electricians doubled up the neutral and ground for each circuit and lots of inspectors passed it. (not me, I was a Tedesco student)
Old 12/3/07, 7:57 PM
Still seeing it nearly everyday (okay twice a week now, they're doing it correct in most New Construction)
- Mike
NACHI05040682
(843) 442-9755
Old 12/4/07, 12:29 AM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Here's what I tell em. They can like it or not!
The problem(s) discovered in the panel such as
  • Item # 1 yada yada
  • Item # 2 yada yada
  • more than one “grounded conductor” (neutral /white) wire per screw on the neutral bus bar (double tapped/lugged) Each “grounded conductor” is supposed to have it’s very own screw on the bus bar, no other “grounded conductor” or “ungrounded conductor” (bare copper wire) should be under the screw with the “grounded conductor”.
    {Some electricians (who haven't done their homework) will tell you that it is OK to have more than one neutral (white) wire under a screw on the bus bar. They are wrong. It has long (at least as far back as 1967) been required by manufacturer's instructions and Underwriters Laboratories Standard 67 for panelboards. See this link for a narrative description of the reason for single neutral wire - single screw. Double Lugged Neutral Narrative Also see this link for a visual interpretation. Double Lugged Neutrals Visual}. Ensure the electrician is familiar with UL Standard 67 requirements
and any other problems that an electrician may discover while performing repairs need correcting. I recommend a licensed electrician repair as needed.
So goes life. You can lead a horse to water. You can shove his head under the water, but you an't make them drink.
Old 12/4/07, 1:09 AM
Christopher Currins's Avatar
Like this one built in 2003. Nice work, but a little lazy when there were plenty of screws left open on the bar.
Christopher Currins
Certified, Licensed
Old 12/4/07, 1:57 AM
That is a guy who thinks that is the "right" way. I know it was a very popular way to wire circuits. They thought grouping them was a good thing for some reason. That guy even twisted them together. It certainly wasn't easier or faster
Old 12/4/07, 7:25 AM
Unmoderated Guest
In NY this is not expressly forbidden in resi work. We follow the NY Residential Code and the wording in NEC 408.41 is absent.
You could quote the 408.41 all day long and you'd still be wrong by calling it out. I've even had one of the head inspectors in my area confirm this when I questioned HIM about it.
90% of the other guys I see do it this way.
Maybe SC is similar?
That said..... I used to do this in every panel. It makes for a nice neat panel and there is no searching for the paired ground and neutral when working on a circuit. It has ABSOLUTELY nothing to do with "laziness".
In recent years I have stopped doing it this way. Mainly because it is in the NEC and it is one less thing that can be questioned later. Obviously the NY code is lacking in some areas so I fill in with the NEC when I can.
Old 12/4/07, 7:36 AM
Barry Adair's Avatar
this method must be infectious...just yesterday...some of the grounds aren't under their lug screw just twisted around the rest...looked like homer had been here
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/4/07, 8:14 AM
Speedy...what about 408.21 when it was in the 2002 NEC? Did NY also ignore its statement then as well?
Paul W. Abernathy
Old 12/4/07, 8:20 AM
Michael Larson's Avatar
Even if NY ignored both how does that let them ignore UL67 and the mfgs. instructions?
Electrician signs off 'ganged neutrals'...now what? mgault Electrical Inspections 16 6/2/07 11:09 PM
Electrician or handyman repair? srowe Electrical Inspections 8 1/4/07 9:21 AM
