What is your opinion or the requirement regarding Armored Cable (BX) exposed outside of a wall at the interior of a home? Is it required that it be "in wall" or in an approved conduit? Can it be exposed? I see it often and always call it out as being improper. Just wanted other thoughts.
774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is permitted by the NEC to be run exposed unless subject to physical damage, which is a completely subjective requirement. IMO unless there's a chance of being easily damaged then it's fine if run exposed. The NEC specifically permits AC cable to be run on the underside of floor joists if stapled to every joist.
Jim Thompson is a non-member guest and is in no way affiliated with InterNACHI or its members.
what about inside a basement in a residential home? would this be considered a damp or wet location? I want to run AC cable from an existing junction box fed by conduit on the ceiling to tun another service/fixture. can i use exposed ac cable?
if this is permitted, can i clamp the ac cable outside the ceiling / finished drywall? |
I doubt the basement would meet the NEC definition of Location, wet. If it does you have other issues like serious waterproofing deficiencies.
If the basement were conditioned I don't think it would be a damp location either. This is a case by case basis. The NEC says "moderate degrees of moisture". What that is depends on the person judging the install. |
| Short circuit failures with 12/3 NM-B cable and NM clamp connectors | pabernathy | Electrical Inspections | 10 | 4/17/11 1:43 PM |
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
| Did you KNOW this about NM Cable? | pabernathy | Electrical Inspections | 0 | 12/19/06 8:46 AM |
| Ceilings falling with wires in it. | jsmith3 | Interior Inspections | 9 | 3/16/06 7:24 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
