Old 1/12/11, 2:20 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Extension cord use
Am I correct in stating that extension cords are not allowed to supply permanently mounted fixtures? Even if they are not buried or penetrating through the wall? I am sure the connection at the ceiling junction box is improper.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Old 1/12/11, 2:25 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Extension cord use
I don't think I have ever heard of a fan that is listed for use with a swag kit, nor is the mounting method likely compliant.
The use of the swag kit into the extension cord is improper.
Old 1/12/11, 2:38 PM
Nick Gromicko's Avatar
www.nachi.org/comsop.htm 6.5.8.S
Find a Home Inspector
Old 1/12/11, 2:42 PM
Robert Meier's Avatar
This is what the 2008 NEC has to say. Most improper usage falls under condition (1).
400.8 Uses Not Permitted.
Unless specifically permitted in 400.7, flexible cords and cables shall not be used for the following:
(1) As a substitute for the fixed wiring of a structure
(2) Where run through holes in walls, structural ceilings, suspended ceilings, dropped ceilings, or floors
(3) Where run through doorways, windows, or similar openings
(4) Where attached to building surfaces
Exception to (4): Flexible cord and cable shall be permitted to be attached to building surfaces in accordance with the provisions of 368.56(B)
(5) Where concealed by walls, floors, or ceilings or located above suspended or dropped ceilings
(6) Where installed in raceways, except as otherwise permitted in this Code
(7) Where subject to physical damage
Old 1/12/11, 2:43 PM
Originally Posted by gromicko View Post
This was not a commercial property. Would there be a difference though on whether it was allowed or not?
774 Manor Road
718-514-3393
Old 1/12/11, 2:44 PM
Thanks all. I've got the answer I was looking for.
774 Manor Road
718-514-3393
Old 1/20/11, 4:38 PM
jhugenroth jhugenroth is offline
Please Note: jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
From yesterday. I see this all the time
Old 1/20/11, 4:52 PM
Brian E. Kelly's Avatar
I would agree with this.
But I see Ceiling Fans with a Swag Kit here in AZ all the time, often to a Switched Outlet.
(Can't really use Nicks made up guide as reference for anything either.)
Old 1/20/11, 5:12 PM
James H. Bushart's Avatar
Yes.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 1/20/11, 5:24 PM
Is it a Permanent Fixture if it is not hard wired?
Old 1/20/11, 5:34 PM
A classic "Catch 22"
Garage door opener extension cord cfolsom Electrical Inspections 4 11/22/07 12:49 PM
Extension Cord Wiring psmothers Electrical Inspections 1 6/4/06 9:11 PM
Joe F, update? jtedesco1 Electrical Inspections 54 4/10/06 10:35 AM
