Does anyone have verbiage on why not extension cords should not be used for permanent wiring?
Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
| Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America) |
ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 4/19/09 at 8:18 AM.. |
OSHA has specific language forbidding it, as well as a definition for "temporary" versus "permanent" use.
I can show you why the NEC prohibits it which is a minimum safety standard.
400.8 Uses Not Permitted. Unless specifically permitted in 400.7, flexible cords and cables shall not be used for the following: (1) As a substitute for the fixed wiring of a structure (2) Where run through holes in walls, structural ceilings, suspended ceilings, dropped ceilings, or floors (3) Where run through doorways, windows, or similar openings (4) Where attached to building surfaces Paul W. Abernathy |
I posted this in another thread. I carry this in my inspection bag, and show it to people. Rather than saying "It is not intended to replace permanent wiring, It could short out" I show them this. If you want a better picture, I can send you one.
visuals usually work best.....very nice Michael
Paul W. Abernathy |
At least one or more temporary extension cord(s) was being used for permanent wiring (such as at XXXXXXXX). This is a common but unsafe wiring practice. Also the exposed electrical wiring have the potential to be damaged or become a safety concern as installed. We recommend having a competent and licensed electrician evaluate and then service, modify or repair this condition as necessary to properly and safely correct this.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Extension Cords in Crawl Spaces | Skip Erwin | Electrical Inspections | 10 | 6/25/06 3:39 PM |
| Joe F, update? | jtedesco1 | Electrical Inspections | 54 | 4/10/06 10:35 AM |
