New Construction using an extension cord to plug in both garage door openers - how would you call it out?...
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Here's a little better picture...
Temporary cords used as permanent wiring.
Mike -
From the photo what I'm seeing is a case where the outlet has been placed next to the opener, but the opener's cord doesn't reach because the ceiling is too farther from the opener then the cord is long. Is that correct? I routinely call out extension cords for ceiling fans and garage door openers where the extension cord runs all the way to a wall, then down the wall and into an outlet, as that is improper wiring and unsafe. But in this case, I don't see a problem, as from what I can see there is no way to supply power to the garage door opener which is better then what they chose, and it's not an unsafe or improper use of an extension cord since the cord isn't hanging in a way in which it is likely to be caught or damaged. I am making the assumption that the garage door opener is fairly high, out of reach to normal individuals of course. Hope that helps! -- bz |
Extension cords are specifically listed for temporary use only. The tag, next to the plug, says it all - not allowed.
Agree with Jeff, but kinda agree with Brain too... I'm torn.
The height of the ceiling (slab plan built on a crawlspace with 'racquetball court' garage ceilings) allows only one way to wire it from the opener - Cut and install a new 'pig tail' for the opener... And they have tried very hard to use a heavy duty (same gauge as the cord or better) extension cord as well as having tried to protect it from any physical damage... Any other thoughts?? Thanks for the ones listed... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Could probably drop a receptacle to it from above properly.
Can you elaborate on this? - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Yep. A cord-pendant would work as well. . .
I'll offer both solutions as potentail 'fixes' to the 'problem'...
Thanks guys... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Steel post question | sspradling | Structural Inspections | 42 | 3/2/07 8:59 PM |
| Extension Cords in Crawl Spaces | Skip Erwin | Electrical Inspections | 10 | 6/25/06 3:39 PM |
| Joe F, update? | jtedesco1 | Electrical Inspections | 54 | 4/10/06 10:35 AM |
