Old 12/8/06, 3:55 PM
Robin N. Byrd Robin N. Byrd is offline
Default Exterior
how would you write this up? this is the exterior service.....and not in conduit.
Do i simply recommend getting it IN something, or evaluation by an electrician?
or would you leave it alone?
R. Nicole Byrd
Byrd-House Inspections
Belpre, OH 45714
NACHI #06090597
Old 12/8/06, 3:59 PM
Jeffrey R. Pope's Avatar
Default Re: Exterior
I would call that a damaged cable assembly, which would require repair, not evaluation.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/8/06, 4:20 PM
Great - thank you!! I just wanted another opinion.
R. Nicole Byrd
Belpre, OH 45714
NACHI #06090597
Old 12/8/06, 4:54 PM
wsiegel wsiegel is offline
Ditto Jeff
Keeping your remarks simple is sometimes the easyest and best way to go
Old 12/8/06, 6:09 PM
Hey Guys,
Correct statement Jeff......it should not be something they come along and wrap with electrical tape...that would an improper fix......However, it is important that if they ask..is to why this got this way and obviously it is loose as that is NOT an approved support method...and it moves back and forth along the side of the house and ended up damaging the sheath....so it needs to be repaired and properly supported..otherwise it will happen again.
Paul W. Abernathy
Old 12/8/06, 7:49 PM
that's what we told the client - & showed her while we were there. We didn't want someone to just try & "fix" it quickly & not realize the importance. thanks again!!
R. Nicole Byrd
Belpre, OH 45714
NACHI #06090597
Old 12/9/06, 7:15 AM
David P. Valley's Avatar
So....Ohio homeowners are now utilizing vinly siding components to attach SE cables to the side of the building. Hmmmmmm.
How much do the brackets cost?Attachment 7639
Old 12/9/06, 1:14 PM
Unmoderated Guest
That was most likely the vinyl guys decision to use that for SEU straps when the house was sided. You'd think at pennies a piece they would carry a box each of 100a and 200a size SEU straps on thier trucks.
Naaaah. That would make too much sense.
IMO this is NOT something that should be written up for "repair" or "repair or replacement". This flat out requires replacement. Period.
There is no "repairing" deteriorated old cloth SEU cable.
Old 12/9/06, 3:53 PM
Agreed.....but it must be defered so the electrical contractor can also see it gets done.....sorry Speedy....as a EC when I say repaired it is me saying it needs to be replaced....sorry...lol
Paul W. Abernathy
Old 12/10/06, 11:03 AM
So is that vinyl siding or aluminum siding? We don't see much of that stuff in the Southwest.
Old 12/10/06, 1:28 PM
bandag bandag is offline
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Brian, That's vinyl, what kind of siding do you use in your area?
Old 12/10/06, 4:07 PM
We use Stucco here. And T-111. Plank type siding is very rare, except in the mountains.
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
Insulate Interior or Exterior of Basements mcyr General Inspection Discussion 4 7/24/07 8:27 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
Your opinion needed jonofrey Exterior Inspections 24 2/1/07 12:10 AM
