Old 11/5/07, 4:07 PM
Tom Bramlett Tom Bramlett is offline
Default Exterior AFCI
Just wondering if an AFCI outlet is allowed on an exterior outlet?
Old 11/5/07, 4:09 PM
Jeffrey R. Pope's Avatar
Default Re: Exterior AFCI
Why not?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/5/07, 6:41 PM
gbeaumont's Avatar
Originally Posted by jpope
Why not?
Hi to all,
I can think of several reasons, as an AFCI does not detect ground faults at the same low levels that a GFCI does. Are you sure it was an AFCI??
sounds wrong
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/5/07, 7:13 PM
An exterior receptacle should be GFCI protected, you're right Gerry, but that doesn't mean that it can't be AFCI protected as well.
I know of nothing that would prohibit AFCI protection at exterior receptacles/outlets, hence my question - "why not?"
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/5/07, 8:06 PM
The homeowner added an exterior outlet to operate a small sprinkler system by tying into a bedroom circuit that was protected by a AFCI breaker. The rest of the exterior outlets were GFCI protected. This is the first time I have run into this and was wondering if it is allowed.
Old 11/5/07, 8:20 PM
Brian E. Kelly's Avatar
Needs to be GFCI protected also
Old 11/5/07, 8:22 PM
Having AFCI protection is not an issue. The absence of GFCI protection IS an issue.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/5/07, 8:59 PM
Bear in mind some AFCIs also have 5ma GFCI protection so you almost need the manufacturer spec to answer the question.
Old 11/5/07, 10:24 PM
gbeaumont's Avatar
Hi Jeff, I knew what you were getting at, but it left a "floating" incomplete answer
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/5/07, 10:38 PM
gbeaumont's Avatar
Hi Greg, I know you're right, and that over the next few years the 2 technologies will be combined, but as of right now it is unlikely that an AFCI would be offering the full protection of a GFCI.
BTW, if an AFCI were acting as a GFCI shouldn't it be labled as such on the receptacle??
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 11/5/07, 11:20 PM
Cutler Hammer has the BR-vcc-AFGF line that is an AFCI with 5ma protection
vcc= voltage/current.
BR-115-AFGF is 120v 15a, BR-220-AFGF is 240v 20a.
Old 11/6/07, 2:10 AM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Greg, yes that correct with the BR series breakers and also the CH as well.
but right now i heard but not confirmed yet until i see in print the other manufacters are working on the combation verison of both GFCI / AFCI and i think they will relase it after the first of the year [ after jan 08 ] by that time we should able know more info.
Merci, Marc
Old 11/6/07, 7:42 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Overkill perhaps... but not an issue then?
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/6/07, 8:32 AM
Michael Larson's Avatar
Mike,
Maybe I missed it but did the exterior outlet trip when you tested the GFCI function?
Old 11/6/07, 8:39 AM
The exteriors were labeled GFI's tied to the local GFCI in the garage, they all tripped fine...
The bedrooms were all AFCI protected as was the individual circuit labeled 'Smoke Detectors' - overkill...
- Mike
NACHI05040682
(843) 442-9755
