This is my home but wanted to post as most do not pull off covers as it is not required in a non invasive inspection but I have the following improper electrical practices.
* exterior light with no visible junction box and lacks ground connection. * updated lights and switches lacking the ground connections. So if you were doing an inspection on an older home and was noticing some open grounded outlets would you also mention the lack of a ground at the lights and switches if they had been modified? Also did an inspection for a client how lived in the home and they used drywall screws to secure the receptacle to the outlet. I would not of known if he did not tell me as he lived there. (Last pic) I added a exterior box designated for a wet location but it stall lacks a ground. Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. Last edited by dmacy; 11/29/11 at 10:02 AM.. |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The GFCI protects you even if the circuit is ungrounded.
If I noticed the lack of a junction box where required, I would note it. I only test receptacle outlets to determine if they are grounded and have the proper polarity. My inspections are not technically exhaustive. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
More pics of my house.
I have installed many lights and switches that lack grounds. Also the wiring in my basement at my workshop under the steps was done by a hack. (Me) I may remove the wiring in basement today. I should hire an electrician to do a rewire. Most older NM cable lacking equipment ground. I hate that light in my family room. I here you Joe!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
So you recently re-wired your home using older 2 conductor wiring?
Kitchen was updated and rewired. Panel was updated but is already filled, and will not accept mini breakers even though it states it will. Sump is on its own breaker, new wiring. Want to finish basement, jetted tub and an exterior hot tub, so looking at a 200 amp upgrade. I have had a few areas rewired like office and portions of living. Most was done by an electrician, the shed wiring I did and that is wrong. Live and learn, or die because I burned down my house because I am a dolt!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
While the splice for the flood is now contained in a box there are still issues like the lack of a connector and the cable sheath does not extend into the box.
I hear you. The wires in contact with the metal soffit is not good. Not much room to crawl around up there to rewire. It is on my list for the electrician.
You definatly need an upgrade David.
The one fixture in the family room is made for bedrooms |
Any recommendations for type of fixture? It is between garage and kitchen. The other side of the family has a remote control ceiling fan that is also not grounded. Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
Some of this LED stuff is looking good. You now have remotes for changing cool to warm tones. I used to build my own.(No UL approval) Trac lighting and wall sconces add certain atmospheres however chandeliers would not work in a family room. If you have a flat screen go with trac to avoid screen washout. |
Those lights are (but not really) referred to as boob lights for obvious reasons! LOL As Bob said bedroom lights usually or a hallway. Because they are cheap allot of builders use these fixtures ...I used to get 6 in a box for $39.00 at HD.
Try not to become a man of success but rather to become a man of value! Serving: Collingwood, Creemore, Dundalk, Durham, Flesherton, Hanover, Kincardine, Mansfield, Markdale, Meaford, Owen Sound, Port Elgin, Sauble Beach, Shelburne, Southampton, Stayner, Thornbury, Wasaga Beach and Wiarton. |
Most of the new lighting fixtures cannot be used with 1960's wiring. They will typically say on the box or in the instructions that the conductors must rated for 75° C or 90° C.
