Old 4/2/06, 11:10 PM
jharashinski's Avatar
jharashinski jharashinski is offline
Default Exterior outlet height
Is there a minimum height requirement for outdoor outlets. I would think common sense says above average snow level and lawn mower height. I know 6 1/2' for max height, but I had an outlet (non-gfci), just above grade. Looking for a spec for my report
Thanks
Old 4/2/06, 11:43 PM
Jeffrey R. Pope's Avatar
Default Re: Exterior outlet height
No minimum height. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/2/06, 11:44 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
don't need a spec. for me. i call 'em out as an electrical safety hazard due to close proximity to ground and below posible flood level. did you test it to see if it was live.??
Old 4/3/06, 1:54 AM
Russel Ray's Avatar
Okay.
Since we know there's no minimum height, let me hijack this thread.
Is there a minimum number of outlets required for the exterior of the building?
Old 4/3/06, 4:29 AM
Thanks
1993 NEC, Section 410-57. Receptacles in Damp or Wet Locations.
(e) Installation.
A receptacle outlet installed outdoors shall be located so that water accumulation is not likely to touch the outlet cover or plate.
Old 4/3/06, 6:03 AM
CHAPTER 4 Equipment for General Use
Here's an example of the way changes are proposed see ROP 18-48.
Also read some of the Panel Statements for their action.
Old 4/3/06, 6:57 AM
David P. Valley's Avatar
(e) Installation.
So snow accumulation would bring this installation even higher?
Old 4/3/06, 7:25 AM
away away is offline
Russel,
It looks like at least one at the front and back of the house is required if grade level access is available. That is paraphrased from E3801.7.
Andrew Way
Keystone Residential Inspection Services PLLC
www.keystoneinspections.com
Chimney Height dmacy Exterior Inspections 3 6/22/07 2:56 PM
Max Breaker height. jlybolt Electrical Inspections 5 5/22/07 8:26 AM
Ceiling height question Chris Watkins Interior Inspections 13 5/10/07 7:25 PM
Chimney Height for combustable gas dmacy Exterior Inspections 7 1/21/06 8:58 PM
