What are the requirements on a new home for exterior outlets. Where do they have to be installed? Thanks
Russ |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
GFCI for all exterior receptacles except for snow melting equipment up high: http://www.nachi.org/gallery/electri...ow-melting.jpg
thanks guys....as always...NACHI members ROCK...I am on the job now...Great to ask while doing the inspection and checking back from time to time for the answer...
Along with the front and rear recptacles there is also a requirement for a receptacle within 25 foot of the AC compressor and on the same level. If the one on the front or rear can satisfy this you would only need the two.
Exterior outlets should be "GCFI protected" and in a weatherproof enclosure (bubble type) unless it is located under roofed open porches, canopies, marquees, or similar, and will not be subjected to a beating rain or water runoff.
When did they change the rule that they need to be front and back? Didn't it use to say just two but did not give a location except one near A/C condensing unit?
Thanks!
