Old 7/18/07, 8:04 AM
rcramer's Avatar
rcramer rcramer is offline
Question Exterior Service Disconnect Clearances?
I know the correct clearance for an interior panel is 30” on each side and 36” in front, but is the same clearances required for an exterior main disconnect. As you can see by the picture the main disconnect is under the meter base and is partially behind the ac unit. I could not open the cover to the main disconnect and access the breaker normally, as the cover had the screws missing at the top where it hinged, so the cover would fall straight down instead of flipping up like normal. I guess they did this so there would be access to the breaker. If the AC unit was to be moved about three inches to the right, the cover could open normally. Are any other clearances required? This is a brand new home.
Robert Cramer
Five Star Property Inspections
Your Best & Safest Choice
www.fivestarpi.com
1-877-378-2774
Old 7/18/07, 8:10 AM
David P. Valley's Avatar
Default Re: Exterior Service Disconnect Clearances?
If the acess cover is unable to be accessed, I would simply recommend moving the condenser for adequate access to electrical SE panel. There must be 36 inches of unobstructed space in front of the meter and there must be at least 2 inches of space on both sides of the meter.
Old 7/18/07, 8:16 AM
rcramer's Avatar
Hey David,
Yes that would be the simple choice, but the condenser can not be moved due to the basement windows. ( See Pic.) my question is are there and required clearances other than being able to open the cover normally.
Robert Cramer
www.fivestarpi.com
1-877-378-2774
Old 7/18/07, 8:20 AM
Hey David,
As I stated, 36" in front and 2" to the sides is required at a meter.
Old 7/18/07, 8:30 AM
I've never seen bracketry attached to a building in order to support condensers.
Is that a norm in your area?
We use simple pads under our condensers.
Old 7/18/07, 8:31 AM
rcramer's Avatar
Thanks David
Robert Cramer
www.fivestarpi.com
1-877-378-2774
Old 7/18/07, 8:33 AM
rcramer's Avatar
Yep, brackets have become the norm, we use pads too, but in new construction brackets have become very popular.
Robert Cramer
www.fivestarpi.com
1-877-378-2774
Old 7/18/07, 8:34 AM
Can you tell me why?
Old 7/18/07, 8:39 AM
rcramer's Avatar
1. Security, in our area there have been a rash of thefts of new units. When mounted on the brackets the units can easily be thru bolted and deturs thefts.
2. Helps keep the unit from being damaged due to lawn mowing debris.
3. Better air circulation.
Robert Cramer
www.fivestarpi.com
1-877-378-2774
Old 7/18/07, 8:59 AM
Mike Whitt's Avatar
Unmoderated Guest
110.26 of the NEC gives the clearances for electrical equipment.
Table 110.26(A)(1) gives the depth. In this table for voltages of 150 to ground we must have 36 inches of depth.
110.26(A) (2) Width of Working Space. The width of the working space in front of the electric equipment shall be the width of the equipment or 750 mm (30 in.), whichever is greater. In all cases, the work space shall permit at least a 90 degree opening of equipment doors or hinged panels.
These 30 inches can start on the edge of one side of the panel and move toward the other side or from the center of the panel 15 inches in either direction as long as there is 30 inches total.
In my area the gas meter can be no closer than 36 inches of the electrical panel. This is not an electrical rule but a gas company rule.
Good call
Old 7/18/07, 9:34 AM
rcramer's Avatar
Thanks Mike, good info.....
Robert Cramer
www.fivestarpi.com
1-877-378-2774
Old 7/18/07, 10:16 AM
gbeaumont's Avatar
Hi Dave, we see them alot down here on new construction, it keeps them above the snow line
But seriously, they run more efficiently off the ground, don't rust as fast as they drain better, plus down here we need to install with hurricane strapping which is easier to do on a purpose built mount.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/18/07, 10:25 AM
Regards
Gerry
I forgot...You do get some serious blizzards in Florida.
Old 7/18/07, 10:46 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Take a walk down some of the back alleys in the financial district/China Town/Bay Village in Boston... during the day of course.
I know , I know your reference to brackets was for residential use .... but I couldn't resist commenting.
Old 7/19/07, 7:27 AM
Yeah, I've been there many times and I know exactly what you're referring to.
I really like those rugged metal shelves and I'd like to see them come to my area. I'm just surprised that they're not here today.
Well pump disconnect sfalvey Plumbing Inspections 0 11/17/06 12:23 AM
A/C Disconnect question rslocum Inspecting HVAC Systems 15 9/21/06 12:16 AM
100 Amp Meter, 200 Amp Disconnect jweinberg Electrical Inspections 8 8/15/06 12:32 PM
HVAC Disconnect kgore Inspecting HVAC Systems 11 7/11/06 6:58 PM
Disconnect and Main panel srowe Electrical Inspections 10 6/13/06 7:49 PM
