I didn't make to the breaker quick enough. It just so happened to be a Zinsco panel, and the breaker did not trip when this thing started arcing. . .
Needless to say, I wasn't very popular at the end of this inspection. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What (was) it feeding?------- You are one Deal Killing SOB just like Brian Kelly---- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
That WAS the disconnect for the A/C condenser. . .
well it sure seems disconnected now |
What I figured, looking at it, but can't be too sure in La La Land---
It literally amazes me how many Zinsco's you come across Jeff---- The Breaker happen too fry to the Buss?...in the service panel?--- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Nope. No residual damage other than what you see.
Jeff, they sell replacement Square D and GE at Home Depot, ha. ha.
What did you do that caused that? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
So Jeff, did you recommend they change the entire electrical system; or just that disconnect
Jeff,
Don't feel bad I'm usually unpopular upon arrival... What do ya wanna bet the realtor has Jeff in Time Out? It's a left coast thing ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
That will teach you for tuning on something that was off.
so never mind all that sparky stuff Jeff ....how did the AC perform ?????
There were numerous issues (electrical related) with this property. This happened within the first fifteen minutes while I was running the A/C.
Jeff,
Dont feel bad. I went to a house yesterday that used to have a solar panel for the water heater. There was no evidence of it ever being on the roof. Per the agent, we turned the water on at the meter. The living room flooded because whoever removed the solar panel did not cap the lines. |
I'm not trying to defend a 50 year old Zinsco but there probably was no short circuit/overload to trip any breaker. It was probably a meltdown due to heat from a poor connection.
I have seen a 60 amp AC circuit start a fire before without tripping a breaker, just not enough current to do it, but plenty to start a fire. |
| Consumer Advocacy Group Announces Opposition to Missouri HB 2057!!! | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 37 | 3/14/08 10:14 PM |
| TWO failed compression couplings | Walt Wys | Plumbing Inspections | 9 | 2/26/08 7:02 PM |
| Roof reason contract failed | cbottger | Exterior Inspections | 2 | 10/16/07 8:56 AM |
| Information on failed ductwork in a slab | Kevin Luce | Inspecting HVAC Systems | 2 | 8/23/07 10:06 AM |
