Old 7/27/10, 8:26 AM
Stan Croenne Stan Croenne is offline
Default Faulty AFCI ?
I did an inspection yesterday on a condo that is less than 1 year old. One AFCI breaker in one bedroom trips when the owner uses a vacuum sweeper. She said it doesn't happen every time. I'm calling for review. Anyone had this issue? What causes this? Faulty breaker? Thanks, Stan
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/27/10, 9:24 AM
Default Re: Faulty AFCI ?
Does the same thing happen when she uses the vacuum in another protected bedroom? If so, the breaker is probably not faulty; otherwise it may be.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 7/27/10, 12:49 PM
That room only.
Old 7/27/10, 12:58 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Allegedly, these breakers are intelligent to discern between an arc and the arcs internal to an electric motor.
Maybe this particular breaker was absent on the day this was taught...
Old 7/27/10, 2:11 PM
Originally Posted by scroenne View Post
That room only.
In that case, I would report that the breaker appeared to be faulty.
Frank P. Newman
Dublin, GA
Old 7/27/10, 2:17 PM
David A. Andersen's Avatar
Defer this to a vacuum salesman next time he comes-a-knocking!
BPI# 5015804
Old 7/27/10, 2:29 PM
Brian E. Kelly's Avatar
It is entirely possible the AFCI is Functioning as intended...
Old 7/27/10, 2:43 PM
Jeffrey R. Jonas's Avatar
In my area, typically all bedrooms are on the same afci breaker. If the problem happens in one bedroom, it should happen in all bedrooms. Were the bedrooms on sererate afci, or combined? Is it the same outlet everytime, or all outlets in the room? If only the one outlet, guess where the problem is.
Old 7/27/10, 2:44 PM
... and all others are kaput!
Old 7/27/10, 2:46 PM
You could have a loose connection from something like backstabbing wires into the plug that is arcing in that bedroom which may be downstream from other bedrooms or on a completely different AFCI.
BPI# 5015804
Old 7/27/10, 2:49 PM
Exactly.....
Old 7/27/10, 8:00 PM
Ya, I never cared for backstabbers...
Larry Kage, CMI
231 929 3525
Old 7/27/10, 10:11 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
This note goes in every report I do that has AFCI's.
NOTE: Certain electronic-equipped appliances, including Kenmore, Panasonic and Miele vacuum cleaners, can exhibit start-up characteristics which the arc fault circuit interrupter recognizes as an electrical arc. When this happens the AFCI believes it is sensing a hazardous condition, even though there is no hazardous condition, and the breaker trips. The easiest solution is to use a high quality 16 gauge extension cord plugged into an outlet outside of the bedroom.
www.MauiHomeInspections.com
Old 7/27/10, 10:42 PM
Andrew Cox Andrew Cox is offline
Geez - that would suck!
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 7/27/10, 11:25 PM
Mark, Have a link to where this info is provided?
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
AFCI Controversy rcooke Electrical Inspections 11 9/10/07 2:14 PM
AFCI's Explained by Mike Holt & Eaton Engineer pabernathy Electrical Inspections 19 2/15/07 12:05 PM
