Old 8/22/13, 11:23 AM
John Ritter John Ritter is online now
Default Federal pacific
Have a federal pacific 200 amp main service disconect. Should it be reported on as needing replacement? Panels have been replaced.
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/22/13, 11:26 AM
Roy D. Cooke, Sr's Avatar
Default Re: Federal pacific
Why did you see any thing wrong with other then the name .
Looks OK to me .
.So I see no reason to report it.
If it said SQ D on the out side would you be asking this question
Old 8/22/13, 11:31 AM
Looks OK to me .
Probally not ,just wanted to hear from some others to see if the name scared you.
Old 8/22/13, 11:43 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Many here are "scared" of the name, so don't be surprised when someone jumps in and calls it a latent fire hazard.
Disregard any such response and look at the panel/disconnect for yourself.
In this particular instance, I see no reason to give this disconnect a second look.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/22/13, 12:15 PM
Joshua L. Frederick Joshua L. Frederick is online now
There's nothing "Stab-lok" about this panel/breaker. The ones that had "issues" were the Stab-Lok type. FP made other panels that didn't use stab-lok breakers.
Old 8/22/13, 12:35 PM
What are your concerns with stab-lok and what do you say about them .
Thanks... Roy
Old 8/22/13, 12:49 PM
Thanks I appreaciate the response. Only issue was the name, everything else was good. CMA
Old 8/22/13, 1:05 PM
Greg Bell, Sr's Avatar
Greg Bell, Sr Greg Bell, Sr is offline
The insurance company may have a problem with it if you did a four point.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 8/22/13, 3:03 PM
Some times there is just no way to win. This was on my mind, but I was only doing the home inspect today. With no defect to the discount there is nothing to report, with insurance it needs reporting. Thanks
Old 8/22/13, 6:27 PM
Jeffrey Belfus Jeffrey Belfus is offline
Stab-lok FP breakers were known to overheat and not trip under a fault. When I see them in a home I just report that it is working or Not and give a link where the customer can read some info on it for themselves.
Old 8/22/13, 6:29 PM
Gee would you post that link so we can all see this information . Thanks . Roy
Old 8/22/13, 7:30 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Judging from the size of that it appear to only be a disconnect switch and not an OCPD.
Old 8/22/13, 11:13 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
looks like a service disconnect to me...200 amps...and it was off next to the meter. Looks like the service breaker to me.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Old 8/22/13, 11:25 PM
Please research the info you're passing off to your clients. The site you provided in your subsequent post is full of misinformation and unsubstantiated allegations.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Federal Pacific Panel opinion khouse1 Florida Inspectors 27 5/6/13 9:07 PM
Federal Pacific Controls jleahy Electrical Inspections 1 6/19/12 7:53 AM
Federal Pacific System and Homeowner Wiring pmagrone Electrical Inspections 2 8/2/07 5:30 PM
Federal Pacific Panels cbottger Electrical Inspections 26 8/22/06 12:43 PM
