Old 6/3/06, 7:51 PM
Curtis Petty Curtis Petty is offline
Default Federal Pacific electrical panels
I inspected a home that had a recalled federal pacific panel installed
in a 1989 home.There were no visual defects,but if a breaker was to go bad they would have to change the entire panel.Can anyone lead me to the re-call information on these panels?
I NEED A PROFESSINAL OPINION !
Old 6/3/06, 7:52 PM
Jeffrey R. Pope's Avatar
Default Re: Federal Pacific electrical panels
FPE has never been recalled!!
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/3/06, 7:56 PM
Jeff-The electrician said the panel does not exsist any more.What happens in they burn/or damage a breaker.The electrician said they no longer have the type they would need?
Old 6/3/06, 7:59 PM
jeff did you see what I wrote back and can you help out?
Old 6/3/06, 8:01 PM
There are replacement breakers available and still in production. The electrician misinformed you.
There has never been a recall on FPE or its breakers, although the Stab-lok load centers were "branded" as hazardous http://www.inspect-ny.com/fpe/fpepanel.htm
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/3/06, 8:07 PM
Thats the type of panel Stab-lock.My customer has concerns about this panel.I have noted no visual defects and proper awg conductor,no arcing present but they still insist the seller replace the panel.
Old 6/3/06, 8:10 PM
Give them the info, send them the link, but don't say it has been recalled. That simply isn't true.
I would be one pissed off seller if you made a false statement such as that.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/4/06, 12:23 AM
tneumann's Avatar
tneumann tneumann is offline
Give them the info...let them argue w/ the seller that isn't your job, unless they want to split the commission?
Old 6/4/06, 11:57 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
If they want it replaced that is between them and the seller. In either case it doesn't cost that much to have that done. $100.00 to 200.00 for supplies & labor. A good electrician should be able to change over the panel in under 3-4 hours unless there are some major problems with the original wiring.
Peace of Mind for under $500.00. Am I wrong?
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 6/4/06, 12:21 PM
Those must be MI prices Jason. A new 100 amp service sets you back at least $1200 in these parts.
That's still a small price to pay as far as I am concerned.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/4/06, 12:26 PM
Roy D. Cooke, Sr's Avatar
http://www.schneider-electric.ca/www...l/19451968.htm
These panels are still being manufactured and used in Canada.
I do not know if they are much different then what you have in the USA .
I think that around 50% of the homes I inspect have them .
They are not a big concern and I have seen no more difficulties then I see in other installations .
Roy Cooke sr. Royshomeinspection.com
Old 6/4/06, 12:47 PM
You have got to be kidding!
I can go to any Home Depot or Lowes and buy a Square D for under $100.00
http://www.lowes.com/lowes/lkn?actio...VP5&lpage=none
Square D Company
100 Amp Main Breaker Panel Value Pack
Item #: 39032 Model: HOMVP5
$54.91
Contains: (1) 20 space 20 circuit panel main breaker panel and (5) 20AMP single pole circuit breakers
Indoor
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 6/4/06, 12:54 PM
Square D Company
200 Amp 30/40 Main Breaker Panel Value Pack
Item #: 39537 Model: HOMVP9$119.00
30 space, 40 circuit
Contains: (1) HOM3040M200TC panel, (1) equipment ground bar, (6) 15AMP and (6) 20AMP single pole, (1) 30 AMP and (1) 50AMP two pole circuit breakers
For indoor use
http://www.lowes.com/lowes/lkn?actio...VP9&lpage=none
GE
32 Space, 200 Amp, Main Breaker Load Center Contractor Kit
Item #: 103821 Model: TM3220CCU2K$110.00
Interchanging of GE breakers and load centers with other manufacturer's products voids GE's life time warranty
UL listed
200 amp, 32 circuits
Single phase, 3 wire, 120/240/volts AC
Includes the following 1" breakers: ten single pole 20 amp, one double pole 30 amp and one double pole 50 amp
Uses TGK32 ground bar kit if necessary
Factory installed main breaker
http://www.lowes.com/lowes/lkn?actio...U2K&lpage=none
Cutler-Hammer
200 Amp Indoor Load Center Value Pack
Item #: 101588 Model: BR3040B200V$99.00
30 space, 40 circuits
Type BW 10kAIC breaker
Aluminum bus
NEMA 1- indoor use
Includes BR3040B200 loadcenter, With 5-BR120 and 1-BR230 branch breakers
http://www.lowes.com/lowes/lkn?actio...00V&lpage=none
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 6/4/06, 1:03 PM
Around here it would be at least $1,200 for a qualified electrician to upgrade to 150 to 200 amp.
Old 6/4/06, 1:20 PM
Paul W. Abernathy's Avatar
Glad I am not working in YOUR state........NOT worth my time for $ 500.00 bucks.......a DIYer maybe..not a REAL contractor...
Try about $ 900 to $ 1,500 bucks.........and depending on the amount of work....5-6 hours.....
Paul W. Abernathy,CMI,CPI,CME
Federal Pacific electrical panels Harvey W. Kelly Electrical Inspections 3 9/6/07 11:55 AM
Federal Pacific Panels cbottger Electrical Inspections 25 8/22/06 1:43 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 2:48 AM
Federal Pacific Panels gbeaumont Electrical Inspections 7 1/2/06 1:55 PM
