Are these a problem panel ?
This Main panel is installed in a Mobile Home built in 1972. Its a 100 amp and I didnt observe any defects... ![]() ![]()
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I say yes, but there are others here who will say no.
If you took the cover off, you're fairly lucky that at least one of the breakers didn't fall out. Some people have observed problems with the breakers failing to trip in overcurrent situations. I know there's verbage available on the forum that others use, if you do a search for "Stab-Lok" you'll find it. “Of liberty I would say that, in the whole plenitude of its extent, it is unobstructed action according to our will. But rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual.” - Thomas Jefferson |
http://www.inspectapedia.com/fpe/fpepanel.htm
Dan Freeman's site has some great info.... and for other topics too. His site has been around for a long time. Take a look. |
thanks...I will check the website
I forewarn each client that, when they follow my advice and have an electrician come out to replace the box, they can expect one of two responses from them. One electrician will say "It has been here for 40 years without a problem and seems to be working fine" and suggest that you not change it. Another electrician will tell you of all the troubles there were with these type of breakers when they were new....and at forty years old...the chances are even greater of something going bad with them.
In either case, while I am not a licensed electrician, I have been contracted by you to advise you as to the conditions of the systems within this home and I would be remiss not to mention the history of trouble with this electrical service panel. If you do not replace it, at the minimum...place a smoke detector a foot above it on the same wall. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
You're welcome. Your "radar" was working there. Peruse around the inspectapedia site, there's a wealth of info like that of the FPE panels. Zinsco is another you'll find a fair amount of in CA. abspipes.com is another one since your in Cali |
Tim,
The first pic on the website you posted should more than seal the deal on his report. Just put that in there. Just add the link, the buyer should be able to figure out the rest. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Unequivocal "yes" in my neck of the woods.
Sean,
Dan's site is one of the greats.... chock full |
jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Then I tell them to get it IN WRITING. “Of liberty I would say that, in the whole plenitude of its extent, it is unobstructed action according to our will. But rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual.” - Thomas Jefferson |
Advise and leave it there...
If there are no documented concerns, it's OK at the "time of inspection". You are there to take a snapshot in time, not predict the future. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Main panel...recommendation ? | dnasser | Electrical Inspections | 6 | 11/22/09 9:55 PM |
| Main panel question | jfrederick | Electrical Inspections | 4 | 1/29/09 10:10 PM |
| Subpanel wired as main panel. | jlybolt | Electrical Inspections | 15 | 5/23/07 4:10 PM |
| Main service disonnect question | jmichalski | Electrical Inspections | 5 | 1/29/06 4:32 PM |
