Old 12/5/11, 6:32 PM
Jonathan N. Leahy Jonathan N. Leahy is offline
Default Federal Pacific Panel
I looked at a house yesterday that had a Federal Pacific Panel. I noted that 3 breakers had been replaced with Challenger breakers. Are Challenger breakers approved replacement breakers in a Federal Pacific Panel?
Any insights will be greatly appreciated.
Thanks
Jonathan
Jonathan N. Leahy
President
A Rock Solid Home Inspection, LLC.
www.arocksolidhome.com
303-718-7779
Residential Home Inspections, Radon Testing, Mold Inspections
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/5/11, 8:20 PM
wsiegel wsiegel is online now
Default Re: Federal Pacific Panel
No, they are not.
Old 12/5/11, 9:34 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Although I would take Challenger breakers over Federal Pacific any day.
A Federal Pacific Electric "Stab-Lok" service panel is in use. These panels and breakers are a latent hazard and can fail to trip in response to over current, leading to electrical fires. The breakers may also fail to shut off internally even if the toggle is switched to "off." Some double-pole (240-Volt) FPE circuit breakers and single-pole FPE Stab-Lok circuit breakers simply do not work safely. There are other panel-defects independent of the breaker problems, panel and panel-bus fires and arcing failures in some equipment. The failure rates for these circuit breakers were and still are significant. In some cases failure to trip occurs 60% of the time - a serious fire and electrical shock hazard. Failures are documented in the CPSC study and by independent research. Have a licensed electrician make further evaluation and corrections as needed.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/5/11, 9:51 PM
Roy D. Cooke, Sr's Avatar
Sorry I disagree with your post .
ESA does not say this and they are still manufactured in Canada.
Roy
Old 12/6/11, 7:30 AM
KEVIN WOOD's Avatar
I know Roy! You still can be my friend. LOL
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/6/11, 3:00 PM
Inform, document, refer, collect the check, done. IMO, I recommend replacement on all FPE panels. I just let the buyer know, refer him/her to web sites, let them decide.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 12/6/11, 8:47 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
Possibly a dumb question, but... The names "Federal Pacific" and "Stab-Lok" seem to be used interchangeably. Are there FPE panels that are NOT Stab-Loks that are not problematic?
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 12/6/11, 9:04 PM
Sean Fogarty's Avatar
Originally Posted by wsiegel View Post
No, they are not.
Is that even possible??
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 12/6/11, 9:08 PM
KEVIN WOOD's Avatar
It is the way the breakers are installed on the bus bar.
They are stabbed into position and they are supposed to lock.
If you have opened a panel with FP with SL and had the breakers fall out. You have just experienced the locking mechanism failure.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/6/11, 9:58 PM
Christopher Currins's Avatar
That's what Sean is stating, how is it possible to install Challenger breakers?
Christopher Currins
Certified, Licensed
Old 12/7/11, 1:19 AM
I did advise the client of the issues with Federal Pacific panels and advised to have an electrical contractor fully evaluate the panel.
Thanks
Jonathan
Jonathan N. Leahy
President
303-718-7779
Old 12/9/11, 10:44 AM
Mark L. Brown's Avatar
Mark L. Brown Mark L. Brown is offline
You did not mentioned, but were branch circuits connected to the challenger breakers, or were they simply plugging missing twist outs? The challenger breakers I've seen did not mechanically appear possible to connect to the buss.
You are correct to point this out at any rate, as the breakers are improper for this panel.
Old 12/9/11, 10:52 AM
Jonathan, was the tag on the inside of the panel showing a 'list of compatible breakers' there? A lot of older panels are missing these labels, but it is a good place to start.
Old 12/9/11, 11:13 AM
Jeffrey R. Jonas's Avatar
One problem with an older panel is that at the time the panel was manufactured, many now compatible breakers did not exist.
Old 12/9/11, 11:32 AM
Jeffrey R. Pope's Avatar
I seem to recall Challenger breakers that were specifically made for use in FPE Stab-Lok panels. I will check into it a bit further, but I'm almost certain they exist.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
federal pacific panel box pcavalcante Electrical Inspections 5 4/7/11 3:53 PM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Main panel...recommendation ? dnasser Electrical Inspections 6 11/22/09 9:55 PM
Federal Pacific nbhi Electrical Inspections 5 11/23/08 9:34 AM
