Old 6/8/11, 5:14 PM
Lee Curtis's Avatar
Lee Curtis Lee Curtis is offline
Default Federal Pacific Panel Date
Citizens in Florida is asking for the date of the latest update on this old Federal Pacific panel.
After a carefully reviewing pictures if found "J1977" Stamped on the paper Legend. Would this be evidence of the latest update? See first pic.
2nd pic is from inspectapedia with a similar looking number G1478
This makes me think it is month/year. Other than this after lots of research I cannot find a definitive "date of manufacture" website.
federal-pacific-panel-date-inspection-021.jpg   federal-pacific-panel-date-fpe1tx.jpg
Lee Curtis - Home Inspector
Revealing the Secrets of Your Home!
CGC1519195 - HI3222 - InterNACHI #11011001
Lee@CurtisHomeInspections.com
www.CurtisHomeInspections.com
www.CurtisHomeDesign.com
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/8/11, 5:18 PM
Charley L. Bottger's Avatar
Default Re: FP Panel - Date of latest upgrade
Originally Posted by lcurtis1 View Post
Citizens in Florida is asking for the date of the latest update on this old panel.
After a carefully reviewing pictures if found "J1977" Stamped on the paper Legend. Would this be evidence of the latest update? See pic.
What is the age of the home probably no update done my guess
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 6/8/11, 5:20 PM
Lee Curtis's Avatar
The home was built in 1955. It probably didn't have central air at that time. It has central air now.
Old 6/8/11, 5:27 PM
In 1955 was probably lucky to have a 100 amp panel and if a load test was performed today your panel would most likely fail the test my guess again hard to tell from here
NACHI Member
State License # 130
Old 6/9/11, 12:30 PM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is online now
Default Re: Federal Pacific Panel Date
You could use the date system you suggested as that is what several manufacturers use (A-K) 1-12, but there is the possibility it may be original.
You may want to contact these guys: FPE replacement, and they may tell you for sure.
More than likely, it was originally fuses and only had a 60 amp service, no central air, and a gas water heater and range.
When the central air was added, they upgraded the electric to, hopefully, 150 amps and changed to breakers. I base that on the physical size of the door in your picture, as the 100 amp FPE panels were much smaller. I can't make out everything on the label.
Judging by the manner in which the panel was labeled, I wouldn't be too sure as to who installed it. A permit search may be helpful.
Federal Pacific Question. lrollins Electrical Inspections 27 11/25/09 12:01 AM
100amp upgrade to 200 amp jmayeaux Electrical Inspections 42 6/27/08 9:55 AM
Old panel configuration for comments dnice Electrical Inspections 8 9/9/07 1:35 AM
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 4:10 PM
