I found this today. A bank of FPE Stab-Loks and 10 amp meters. You think maybe this is an original intallation?
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 2/28/07 at 3:15 PM.. |
Hi to all,
Jeff, i am guessing here, but those can't be 10amp rated meters as such, surely the 10 amp is the calibration load. Personally I have only ever seen one meter smaller than 60 amp and that was a 30, many meters however are calibrated under 15amp load. BTW, the design of that meter appears to be 1930, maybe 40's Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 2/16/06 at 8:29 PM.. |
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
The meter (as I remember) is calibrated at the indicated amperage, however, they operate under heavier loads. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
A B D C ??? did someone put the wrong cover on the panel, or did they wire it wrong a swapped 'em after.
| Federal Pacific electrical panels | Harvey W. Kelly | Electrical Inspections | 3 | 9/6/07 10:55 AM |
| Federal Pacific electrical panels | cpetty | Electrical Inspections | 35 | 4/13/07 7:39 PM |
| Federal Pacific Panels | cbottger | Electrical Inspections | 26 | 8/22/06 12:43 PM |
| FPE Panel - Do you open them up? | menser | Electrical Inspections | 11 | 2/7/06 6:31 PM |
| Federal Pacific Panels | gbeaumont | Electrical Inspections | 7 | 1/2/06 12:55 PM |
