Does the NEC actually demand or even suggest that Federal Pacific Bkrs/Boxes be removed?
Also, if someone lives around Nashville... Do the Nashville "Metro Codes" actually demand or even suggest that Federal Pacific Brkrs/boxes be removed? |
| Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America) |
NO
But we are not code Inspectors. Just do a search on the subject. |
Thanks... I understand the problems with Fed Pac. They have been around for 20+ years now. I just had a client ask me if it was mandated that the change be made and I answered no. Then I got wondering and second guessing myself. She has the standard blerb that I give... if that doesn't scare her... nothing will! Thanks!
Stab-lok panels date back to the '40's. They've been around much longer than 20 years. . .
I meant that the problems with such have been known for 20+ years. I'm thinking back when I owned a hardware store during the 70's and 80's and stopped selling FPE products when they were sued into oblivion only to be resurrected by the employees and who knows after that. Sorry I didn't make that clear.
I always tell them to have a Electrician evaluate as a precaution.
This includes Zinsco. |
The answer to your Nashville question is : No. As far as the reporting requirements of the TN Dept of Commerce and Insurance, you need more than hearsay to require panel replacement. If it's hot, broken or doesn't work you report it. Not just because of it's name. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
*** Safety Warning*** I have observed a Federal Pacific Electric "Stab-Lok" service panel in the house. This panel is a latent fire hazard: it's circuit breakers may fail to trip in response to an overcurrent or a short circuit. Failure of a circuit breaker to trip can result in a fire, property damage, or personal injury. A circuit breaker that may not trip does not afford the protection that is intended and required. Simply replacing the circuit breakers is not a reliable repair. The panel should be replaced, and significant expense may be involved. Additional information about the fire and shock hazards associated with this equipment can be read on the internet at http://InspectAPedia.com/fpe/fpepanel.htm. Additional Reading Explanation
Bill Boerner STL Home Inspection ServicesServing St. Louis/Surrounding (314) 805-2137 billy.boerner@gmail.com http://www.stlhomeinspector.com Last edited by bboerner; 11/21/09 at 10:27 AM.. |
Is that truly what you want to do and feel is right? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
My state law (and most don't) "require" this evaluation or diagnostic.
There is no basis for this responsibility to fall on a home inspector (who is conducting a visual inspection for significant deficiencies). You show me in the law, where I have to report this situation!? If this was in fact such a huge hazard in 100% of the existing panels, why have they not been all recalled in a class action law suit? Quote:
Either get the tools and/or perform the procedure to determine the panel is bad or keep your recommendations of replacement to your self. Your article says you must report "Not too strong" (or your wrong) and" not too soft" (or your still wrong). If I needed to report this, my state law would say exactly what I need to say about it. Just like everything they say I must say in every inspection. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Are you saying that all problems will be surface related and if we don't see a problem we should let well enough alone without posting a message that the panel could lead to a possible fire? Bill Boerner STL Home Inspection ServicesServing St. Louis/Surrounding (314) 805-2137 billy.boerner@gmail.com http://www.stlhomeinspector.com |
It is not our job. If it is not detectable under the Standards of Inspection set by law, it's not part of the inspection and it is NOT YOUR JOB. Someone else out there takes care of these things. Not Home Inspectors. If you want to debate this, start by posting the Standards of Practice that states we must report this situation. Here you go (for your convenience). 2.7. Electrical I. The inspector shall inspect: A. The service line. B. The meter box. C. The main disconnect. D. And determine the service amperage. E. Panels, breakers and fuses. F. The grounding. G. The bonding. H. A representative sampling of switches, receptacles, light fixtures, and test all GFCI receptacles and GFCI circuit breakers observed and deemed to be GFCI's during the inspection. I. And report the presence of solid conductor aluminum branch circuit wiring if readily visible. J. And report on any GFCI-tested receptacles in which power is not present, polarity is incorrect, the receptacle is not grounded, is not secured to the wall, the cover is not in place, the ground fault circuit interrupter devices are not properly installed or do not operate properly, or evidence of arcing or excessive heat is present. K. The service entrance conductors and the condition of their sheathing. L. The ground fault circuit interrupters with a GFCI tester. M. And describe the amperage rating of the service. N. And report the absence of smoke detectors. O. Service entrance cables and report as in need of repair deficiencies in the integrity of the insulation, drip loop, or separation of conductors at weatherheads and clearances. II. The inspector is not required to: A. Insert any tool, probe or device into the main or sub-panels. B. Operate electrical systems that are shut down. C. Remove panel covers or dead front covers if not readily accessible. D. Operate over current protection devices. E. Operate non-accessible smoke detectors. F. Measure or determine the amperage or voltage of the main service if not visibly labeled. G. Inspect the alarm system and components. H. Inspect the ancillary wiring. I. Activate any electrical systems or branch circuits which are not energized. J. Operate overload devices. K. Inspect low voltage systems, electrical de-icing tapes, swimming pool wiring or any time-controlled devices. L. Verify the continuity of the connected service ground. M. Inspect private or emergency electrical supply sources, including but not limited to generators, windmills, photovoltaic solar collectors, or battery or electrical storage facility. N. Inspect spark or lightning arrestors. O. Conduct drop voltage calculations. P. Determine the accuracy of breaker labeling. If you look up the TN Home Inspection Licencing Law you will find that there is NO "Required Reporting Criteria" in the Electrical section of the law as there is in other sections of the law. Quote:
I just note that a FP panel is present and the buyer needs to check with their insurance company for insurability. If the client asks than I expalin both sides of the story and let them decide.
Yup. Same here.
When I see one of these, I look a lot harder and do more testing. I have never recommended panel replacement without documented issues. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
David, thank you for the definitive "No" which was the answer I was looking for.
Now with all due respect...and I do respect your opinion, here are the problems I have with your analysis. "As far as the reporting requirements of the TN Dept of Commerce and Insurance, you need more than hearsay to require panel replacement. " It is my understanding that I, as a HI, do not have the authority to require the replacement of anything. The TN Dept. of Commerce and Insurance never issued me a badge and a gun. I simply report what I see and in certain cases recommend to the client that he seek further more "expert" advise. "If this was in fact such a huge hazard in 100% of the existing panels, why have they not been all recalled in a class action law suit?" You're using an "all or nothing" analogy here. Which, no matter what the subject, is wrong most of the time. Of course, FPE equipment does not fail 100 % of the time... nor does any other product that proves to be faulty and gets recalled or the company is subject to numerous lawsuits as was FPE. Years ago I had a hardware store in northern NH. We sold FPE products for years. Recalls were not popular in the 70's and 80's. If a product was bad the company would get sued over and over until they stopped producing it, went under, or the government stepped in. FPE was sued over and over during that time period, and was eventually sued out of existance. A number of months later the company was resurrected by the employees and they went right back to stablok. They continued to have problems with stablok and in 1997 a Canadian recall was announced. I do not believe that a US recall has ever been made. There is a long... well documented series of problems with FPE products and I fully understand that there are those that still decide to stick there heads in the sand. I stopped selling FPE in the early 80's because I felt there was sufficient evidence to warrant not selling them to my customers. Today, I have seen no evidence to the contrary, and will continue to recommend, as a HI, that my clients seek further "expert" advice. "Either get the tools and/or perform the procedure to determine the panel is bad or keep your recommendations of replacement to your self." First of all the "recommendation of replacement" are your words not ours and certainly not mine, although I admit to having removed two FPE panels from apartments I own on this very day. Which was, by the way, the reason I started this thread in the first place. I can think of many examples of items I would bring up in my report that are not directly mentioned in the law. I can also think of many that I would not need to "tool and test" before mentioning. One never knows what we will find in a home, for instance, If I was to find something that in my experience, looked like it could be a pound of spilled gunpowder in the cellar next to an old reloading bench. It would certainly go into my report and I would certainly recommend that the client seek expert advice. I would not feel the necessity to test it because as a HI, I do not have an expertesse in explosives. I feel, as HI's, we are required to be expert in one thing only.... locating problems and/or potential problems. Unless we are licensed to be an expert we should not act as such. Maybe you are a licensed electrician and, as such, have been authorized by the state to act as an expert in these matter. If not, I would suggest that you think about possibly recommending experts in your reports rather than writing as one. I agree with you on inspectapedia. It is one of many sources that are available to us as HI. Personally I feel they overstep there boundaries when they try to tell us exactly what we should do and how to do it. I use these sources as suggestions only. This has been an interesting thread for me and I thank you for your input! |
| Federal Pacific - The definitive answer | jfarsetta | Electrical Inspections | 57 | 3/21/11 8:48 AM |
| Federal Pacific 200 Amp Fuse Panel | jhagarty | Electrical Inspections | 2 | 1/24/07 1:12 AM |
| Federal Pacific & Barry Stone | rray | Electrical Inspections | 3 | 1/23/07 9:52 AM |
| Federal Pacific Service Panel | jweeams | Electrical Inspections | 18 | 9/14/06 8:57 PM |
