Never seen this before, a duplex with 2 100A panels, seperate feeds to each panel fed by a single feed from the pole. They are all spliced together under the eave. Thoughts?
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Fairly common in my area, which has many converted SFH's.
Compliant - 230.40, Ex. 1
Just remember that in that allowance you still need to meet compliance with NEC 230.71 and 230.72. However, that is well beyod what your question was. Paul W. Abernathy |
Thank you Paul. Yes Both feeds had their own meter, and both panels had their own main disconnect.
Te answer to the next question is ....Yes I did just go look that up. Why? Because Im not Paul Abernathy.... ( bows) |
I believe that is up to the utility. They do not get involved in the NEC
lol...trust me fella....YOU dont want to be me....I have alway had issues.. Paul W. Abernathy |
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
