grounded conductor (neutral) same lug at QO Load center?
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Grounded and grounding conductors are required to be bonded (connected) at the service equipment, but this is definitely not the proper way to accomplish it.
Is that solid copper conductor in a raceway? If so that would also be a problem since conductors larger than #10 in raceways are required to be stranded.
Ron Waller is a non-member guest and is in no way affiliated with InterNACHI or its members.
A simple question: In a 200 amp main panel, would there ever be an expectation for more than 100 amps in each of the balanced legs?
With a 200 amp panel at 240 volts you would have a capacity of 200 amps. At 120 volts you would have a capacity of 400 amps. |
What is "feeder equipment"?
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 2:00 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
