Old 11/9/11, 8:31 PM
Amir Faghih Amir Faghih is offline
Default Few electrical questions
I always seem to get confused as to when electrical breaker box needs to be grounded , bonded or both. any explanation would be appreciated
when main panel should be bonded or grounded or both. When sub panel should be bonded or grounded or both.
What about older wiring system, when there are no bonding?
Also, what is the latest ragarding GFCI. Area ll plugs in garage, including the one for garage door opener must be GFCI?
Lastly: how do I know if recess lights should not have insulation over it in attic. Is there an easy way to determine that, other than reading the label. What if the home owner has CFL light bulbs in the light fixture and so they will not get as hot?
Thanks
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/9/11, 9:32 PM
Jeffrey R. Pope's Avatar
Default Re: Few electrical questions
It's important to understand the difference between grounding and bonding.
Any metallic enclosure (j-box, panel, conduit, outlet-box, etc.) is required to be bonded to the grounding electrode system of the residence. This can be established in several ways. For instance, the equipment grounding conductor(s) can be directly attached to the enclosure with proper terminals or bonding can occur through proper connections made with metallic conduit. When this is done properly, all necessary components will be grounded.
I have attached a sheet that covers GFCI requirements up to 2008. I have a more current one on my other computer, but this is a good start.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/9/11, 9:49 PM
Christopher Currins's Avatar
National Electrical Code (NEC) Grounding Requirements
Both the neutral and equipment-grounding conductor is bonded together at a single point via a bonding jumper. (Most often this is the main disconnect or the neutral/ground service entrance bonding buss bar.)
This point is also bonded to Earth via the grounding electrode conductor that bonds the system to the grounding electrode system.
The panel that houses the bonding jumper (or bonding buss bar) is called the main panel (main distribution panel) or can be the service entrance main disconnect.
All subsequent panels and disconnects fed from this point are referred to as sub-panels, distribution panels or disconnects.
Christopher Currins
Certified, Licensed
Old 11/9/11, 11:13 PM
Bob Elliott's Avatar
To answer the can light question.
No slots in the casing mean it is Okay to blow insulation over them.
Old 11/10/11, 6:56 AM
Barry Adair's Avatar
Thanks
http://www.nachi.org/forum/f19/few-e...estions-65988/
Amir Faghih are you yanking our chain?
is TREC aware of your confusion?
licensed since the 90s and a sponsor
if not how much have you missed and how many clients have been ripped off due to lack of electrical knowledge
if not immediate electrical continuing ed is advised
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/10/11, 7:32 AM
Wayne B. Wilson's Avatar
Thanks Jeffrey for the chart. that will come in handy around here.
BTW I thought the MB was for any question to be answered seems lately someone always jumps on someone for some reason , Are HI on some kind of life cycle? lol
Reasonable question , great responses .
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 11/10/11, 8:01 AM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
From the State of Texas mandated SOP:
§535.229. Standards of Practice: Minimum Inspection Requirements for Electrical Systems.
(a) Service entrance and panels. The inspector shall report as Deficient:
(2) the lack of a grounding electrode system;
(3) the lack of a grounding electrode conductor;
(4) the lack of a secure connection to the grounding electrode system;
(6) electrical cabinets, gutters, meter cans, and panel boards that:
(E) are not bonded and grounded;
(c) Branch circuits, connected devices, and fixtures. The inspector shall:
(3) report as Deficient:
(A) the lack of ground‐fault circuit interrupter protection in all:
(i) bathroom receptacles;
(ii) garage receptacles;
(iii) outdoor receptacles;
(iv) crawl space receptacles;
(v) unfinished basement receptacles;
(vi) kitchen countertop receptacles; and
(vii) laundry, utility, and wet bar sink receptacles located within 6 feet of the outside edge of a laundry, utility, or wet bar sink; and
Part of the answers are directly in the Texas mandated SOP. The remaining topics are taught in initial licensing classes and are reviewed in most any comprehensive electrical CEU class offered for license renewal. The answers to the questions are also freely available on the internet for the searching. Are Barry's questions and concerns really unwarranted?
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 11/10/11, 8:41 AM
No not really, but if there is a question and if someone wants to answer it whats the problem ?. if you think it is stupid move on and ignore it. It is getting to a point lately everyone is hesitating to ask anything on here. Personally if i have a questions it could be to get get refreshed on something or to see if something has been updated. this MB is a source of great information . (Pdf files like Jeff added.) can be saved and sent to someone that asks that question . I have a crap load of pdfs from everyone that posts , Marcel , Jeffery, Barry an many others have posted great material If this question was not asked we may not have not had a opportunity of receiving the file .
I am also guilty of snapping a response .
I think we all can be more understanding On HI questions . Now on the other threads not pertaining to HI go at it.
My Answer to you it may be simple question , But it got information out to all.
My theory is there is no stupid questions , If you can not learn something new everyday it has been a wasted day .
I was not criticizing Barry because he is a valuable source of information, I was just pointing out we all have our own weaknesses and strengths. Questions with answers are invaluable. No education courses or SOP's can replace experience. this message board has some of the best experienced people around. Together we become stronger.
Wayne Wilson
865-256-1490
Old 11/10/11, 8:42 AM
Bob,
Air tight non IC rated can lights
http://www.lightfixtureindustries.co...-8-inch-OD.pdf
http://www.lightfixtureindustries.co...IC_11CNS6N.pdf
More without slots.
http://www.lightinguniverse.com/gene...oductItemsName
Since you don't know what the builder, homeowner, installer is going to put in at the attic level you must be careful.
TREC License# 7593
Old 11/10/11, 8:48 AM
Roy D. Cooke, Sr's Avatar
Thanks Wayne I wish more would read your post again and practice more of what you said .
I see so many good Inspectors who have helped many over the years seldom post and many no longer post.
I wonder why some just look for Homies to attack .
They seem to use our great forum and hurt our industry big time .
Well said and we all should try to improve our selves .
Old 11/10/11, 6:40 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Barry, don't hold back your true feelings...hahaha..I am with you bro,
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 11/10/11, 8:45 PM
Jim Port Jim Port is offline
Unmoderated Guest
While no one should be afraid to ask questions about situations they have never come across or need further clarification for someone with over 10 years of experience to be asking these basic types of questions seems ridiculous. I agree with Barry.
If I was a HO that paid for an inspection by someone that appears to lack the required knowledge I would be less than happy.
Old 11/17/11, 12:24 AM
Mark L. Brown's Avatar
Mark L. Brown Mark L. Brown is offline
Wink Re: Few electrical questions
Thanks again Jeffrey for the chart. I have only been performing HI for about 5 years. It is good to know the timing of some of the changes. This will help.
Old 11/17/11, 1:14 AM
Dale Duffy's Avatar
For any one interested in keeping up with new/old requirements, and learning anything regarding electricity, I urge you to visit Mike Holt, and subscribe to his daily newsletters, there is a wealth of information in each newsletter regarding every aspect of both residential and commercial electrical.
His entire website is just loaded with the most comprehensive information available, including classes, tests, quiz's.
If you need expert advise post on Mikes forum, if you search his forum, there really isn't a topic in any aspect of electricity which isn't covered thoroughly.
Use the search option if you don't want to post. Grounding and Bonding can be confusing if you don't know/understand why the requirements are necessary for a safe electrical system.
There is also a wealth of information available online, but posting here is good for others to help, but to learn the most without interruption, look at what is already been hashed over thousands of time.
Old 11/17/11, 7:13 AM
Michael J. Parker Michael J. Parker is offline
Thanks Dale. Great info
Michael J. Parker
The Neighborhood Home Inspector, LLC
Home inspections in Clinton, Essex and Franklin Counties in NY State
http://www.PlattsburghHomeInspector.com
www.TheNeighborhoodHomeInspector.com
Coming to Schaumburg, Ill - Electrical Training with The Electrical Guru ksitzes Inspection Education & Training 12 3/17/10 4:19 PM
Newsletters and Publications: Electrical jtedesco1 Electrical Inspections 2 2/14/08 12:25 PM
Canadian electrical questions bgromicko Electrical Inspections 2 1/4/08 2:23 PM
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Free! NACHI Chapter Electrical Inspection Seminars jtedesco1 Inspection Education & Training 0 10/2/06 4:40 PM
