I truly believe that eventually Darwin’s theory of survival of the fittest will weed out all of the Harry Homeowners that do some of the insane things that we see regularly. This was a repo and I guess that if you can’t afford a new breaker then just add a light switch. I don’t know the purpose of the switch (and don’t want to know). The power was off and I strongly recommended that a qualified electrician evaluate the service panel prior to the power being turned back on.
OMG...you're right...that should have been a 20A, not a 15A !!!
The paint overspray that panel has rendered it unusable anyhow.
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
....Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Rollie Meyers is a non-member guest and is in no way affiliated with InterNACHI or its members.
That overspray looks like spray texture and if so wipes off with a damp cloth.
I think it looks cooooool.
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I do want to know! Why would you run that "switch" to two separate (double-tapped) breakers? Crazy. To think that this made sense to someone? </IMG></IMG> |
What until you open one and everything starts to fall out. Now that is an experience.
Greg Bell Titusville, Fl 02111507 Serving Central Florida
</IMG> |
You could have opened this one.
Courtesy Bryan Holland ECO City of North Port |
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
maybe if that owner of that place did installed the single pole switch inside of the breaker box becuase his past experanice with the current limter metering socket was on before and he have to cross over the dead leg to get it on.
{ Marc Shunk have a photo of what the limter look like and i think he will repost it again if he have time} Merci, Marc |
| Grounded conductors | cduphily | Electrical Inspections | 144 | 11/16/08 10:28 PM |
| QOD 11-1-2006 Electrical | gbell | Inspection Question of the Day | 31 | 11/4/06 5:15 PM |
| Sub panel need cover? | bmargiotti | Electrical Inspections | 13 | 3/5/06 4:28 PM |
| FPE Panel - Do you open them up? | menser | Electrical Inspections | 11 | 2/7/06 6:31 PM |
